Bonnet catch sound proofing
  • Bonnet catch sound proofing
    Don't really know how else to call it - there's 4 bonnet catches all round. I think they are rattling on the road; what do you folks use to 'sound proof' them? Some kind of rubber maybe like bicycle inner tube rubber glued in place or something similar? Maybe there's a rubber washer that can be used?
    Re: Bonnet catch sound proofing
    My bonnet catches are spring loaded and are under constant tension but to stop them rattling against the the bodywork they have a built in rubber stopper thingy that presses against the car.
    Small top quality catch, approx 4.25" / 110mm long overall, complete with catch plate. Chromium plated on brass, small rubber buffer on back. Base plate and
    Derek
    Stumbling around in the dark
    Marina based SWB roadster
      Depends what type they are most popular type like in the link above have a small rubber pip that sits against the panel they should be fitted with a small amount of tension so shouldn't rattle.
        Have a look in B&Q in the plumbing section where they have ball valve repair kits containing different size round flat rubber seals. Also in the cupboard fittings etc area they do some hemispherical rubber feet. They may have a small nail fixing thing on the flat side but that can easily be cut off or maybe pulled out. I have also used a small slice cut off a piece of petrol hose for similar jobs. Peter.
          Thanks for the B&Q tip - I'll have a look next time I'm in town. It looks like some of the rubber pads are worn out (probably deteriorate with age I guess).
            These work really well for loads of different jobs. 3M Silicone RUBBER FEET Bumpons - CLEAR - Round Self Adhesive Anti Slip Circles. get them on ebay for a couple of quid a sheet.
