nuts
  • nuts
    Hello
    Thank you for all your answers
    I look for good qalite wheel nuts for my car
    I do not know the filtage
    thank you
    Re: nuts
    photos
      Re: nuts
      Imperial inch size 3/8" UNF. Mostly used on Triumph cars.
        Re: nuts
        good quality nuts
        company name please
          Re: nuts
          Many, but the first that comes to mind for many parts is http://www.rimmerbros.co.uk/Category...r-Parts--m-602
          the Herald and Dolomite 1500 are similar. Check carefully as different shape nuts fit different wheels.
          http://www.rimmerbros.co.uk/Category...r-Parts--m-602 look the same as yours.
            Re: nuts
            Make sure the angle of the bevel is correct, they can be different.
              Re: nuts
              There are variations but the vast amount are 60°
              Order your Triumph Herald Wheel Nuts ⛽ Low prices and fast, worldwide delivery ✈ British car experts ♚ Call ☎ 01522 568000 or ☎ 1-855-746-2767
                Re: nuts
                this ref is it good?
                Order your Wheel Nut 3/8 UNF 60 Deg Tapper S/Steel - RL1471SS  ⛽ Low prices and fast, worldwide delivery ✈ British car experts ♚ Call ☎ 01522 568000 or ☎ 1-855-746-2767
                  Re: nuts
                  They certainly look the same design and taper of the ones in your picture.
                  These are stainless steel ones so quite expensive, plated or chrome ones are available. I don't think the supplier makes a big difference.
                    Re: nuts
                    I bought a set of these last year. They are excellent and work out less than £2.00 each http://www.ebay.co.uk/itm/151499379728
                      Re: nuts
                      thank you I'll order
