Ital 575 Pick-up Axle
  • Ital 575 Pick-up Axle
    Passing on useful information recently received,
    John.
    Stuart Miles is currently breaking a Morris Ital 575 Pick-up and has the heavy duty back axle and front and rear running gear available.
    He is based in Poole, Dorset and can be contacted on 07517626540, via www.facebook,com/classicandvintage.org , or [email protected]
    Re: Ital 575 Pick-up Axle
    Contact links don't work but a bit of investigation finds the seller, but items are not listed!
    The heavy duty axle sought after by trials owners did not appear on a standard Ital commercials, though it may have been modified at a later date.
    The diff gear ratios were different from the Saloon etc.
    Check carefully before you buy
      Stuart emailed me about this and other bits. I have dealt with him and he does what he says. Contact him with your needs and he will quote.I bought a set of dash clocks.
