Page 26 of 27 FirstFirst ... 16 24 25 26 27 LastLast
Results 251 to 260 of 265
  1. #251 Re: Roadster Rebuild Diary from Cornwall
    Bodmin, Cornwall
    713
    Are you going to put them on the Marina runners like mine?
  2. #252 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    St Austell, Cornwall
    534
    Hi Hugh, I don’t have any Marina runners just a set of universal adjustable runners that were on the old seats. These were mounted on some alloy box section to raise them up a bit.
    Do the Marina runners raise them up so I can do away with the box section?
  3. #253 Re: Roadster Rebuild Diary from Cornwall
    High Wycombe, Buckinghamshire
    1,791
    I have to admit I have bolted mine directly to the floor.
    It does mean that I sit lower and the standard Marlin buffeting isn't so apparent.
  4. #254 Re: Roadster Rebuild Diary from Cornwall
    Oct 2018
    31
    Regarding "how do all the 7's cope" my last daft car was a least loved Caterham (not least loved by me, but least loved by marque officionados. Least loved meant cheapest for sale in the UK when I bought it), the 1600VX Classic which used the 1600 Vauxhall 8 valve OHC engine (big block, so Cavalier/Vectra and not Astra). This always seemed to run cold, so I assumed the thermostat had stuck open and started looking for part numbers on the owners forum. This lead to discover that when Caterham had switched to this engine, they tried every thermostat rating they could find in an effort to stop the lump from overheating. Eventually they hit on the genius idea of leaving the thermostat out altogether. Apparently if anyone realised their Caterham didn't have a stat and rang up to ask for one they were supplied one free of charge from the large box kept under a desk where they put all the stats they originally removed when building the cars. I live in cold Lancashire, not balmy Surrey where they presumably did all their testing, so I did buy a very cheap low temperature opening stat off Ebay for a couple of quid, but i could never bring myself to fit it before I sold the car... I did give it to the new owner, but related the tale and decided to leave it to him to make up his own mind.
    And there was also the time I took a Blackjack Avion to Harewood Hillclimb school on a warm June day and was told in the paddock after a run that I'd left coolant on the circuit. When I lifted the bonnet and they'd gazed at the aircooled twin pot for a few seconds they went to have a closer look at the crossflow engined 7-alike Sylva Striker that had preceded me up the hill and had previously insisted "it wasn't me mate, must have been that weird 3 wheeler".
    For reference, my original Cabrio never seemed to overheat either with a 2 litre Pinto or the eventual 2.8l litre Cologne - but i can't remember if we fitted an electric fan or just kept the engine driven item. But I think the radiator and cowl opening is substantially larger than a Roadster, and the design meant it was easy to make sure pretty much all the air passed through the rad. If I did fit an electric fan it was definitely on the engine bay side.
    My current Roadster did have an electric fan fitted that I've just replaced. Both original and replacement are on the entrance side, mainly becasue there is so little room between steering rack and radiator.
    Original builder of SWB Cabrio chassis no. 04-33 reg. no. CRN540Y - had a 2.8L Cologne V6 when I sold it in 2011
    Current owner of SWB Marian 1800TC Roadster Q741LPP - modified for trials by Fourtune Engineering
  5. #255 Re: Roadster Rebuild Diary from Cornwall
    417
    The box section may be there to strengthen the floor. The flat steel floor can act like the button on a jam jar lid giving the car an insubstantial feel as you step in. With my Cabrio raising the front of the seat also made it more comfortable. I am on the limit on height for a short wheelbase and raising the front of the seat causes your leg to be naturally a little bent.
    I spent a long time with blocks of wood getting the angle of the seats right. Given the hours you may spend sitting in them it’s worth the effort.
  6. #256 Re: Roadster Rebuild Diary from Cornwall
    Bodmin, Cornwall
    713
    My floor is ½" marine ply bolted and silicone sealed in. The runners have a block under the front to tip the seat back a bit, about 1" high.
  7. #257 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    534
    It will be trial and error getting them at the right height.
    I am a short ass 5’8” and with the seats directly on the floor they do feel too low.
  8. #258 Re: Roadster Rebuild Diary from Cornwall
    1,791
    On my long wheelbase I had runners and blocks and that was fine.
    Moving to a short wheelbase I had to get lower otherwise my head was above the screen.
    I still utilise the blocks and it is comfortable for me.
    I am only 5' 8".
  9. #259 Re: Roadster Rebuild Diary from Cornwall
    Bodmin, Cornwall
    713
    You're a short ass, what about me, 5'4"
  10. #260 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    534
    :-) LOL
    Quote Originally Posted by h_m_cumming View Post
Similar Threads
  1. Replies: 0
    Last Post: 20-11-2017, 11:57 AM
  2. V8 Roadster rebuild
    Last Post: 09-11-2015, 06:54 PM
  3. Replies: 22
