Roadster Rebuild Diary from Cornwall
  • Re: Roadster Rebuild Diary from Cornwall
    Thanks and I also can’t wait to see it finished. :-)
    Lovely weather so got the primer on, get it flattened off then all I need is another weekend like this and I can sort the topcoat. Gets bleddy hot in the paint tent.
    Last to paint will be the headlight pods and the spare wheel carrier, nice small and easy bits then on to the brakes, fuel and cooling and all the other unfinished bits.
      Whilst having a bit of a tidy up in the garage I came across the radiator cowl that I took off the car nearly 3 years ago. It is stainless steel and after a bit of a clean up and slight modification to add the fan looks good.
      It was made to house the classic Mini rad so I ordered a new aluminium rad.
      My plan is to use the original engine cooling fan and also wire in the electric fan that is now fitted to the front of the cowl. The fan works in both directions so just need to make sure I wire it so it blows cool air through the rad rather than away from it. I can either wire it to a thermostatic switch or to a switch on the dash, thermo switch will probably be best.
        Are you mounting on the back or front of the rad. Martin? It's much better on the back as it impedes the natural air flow less.
          I agree, mounting on the engine side is better. In addition it gets fewer insects stuck to it and makes cleaning the rad easier.
            I don’t think it makes much difference, it will spin in the airflow anyway, and if needed it will turn on maybe a fraction earlier.
            There is a debate though that curve bladed fans are more efficient spinning in the correct direction.
            Two fans mounted in-line is likely to be a lot less efficient as the air flow from one is likely to cause the other to stall.
              Hiya
              I have mine mounted on the outside pulling air in.
              I have also kept the original fan as this allows for hot air to be pushed out via the shark gills.
              Will add a picture in a moment.
                Note: I have retained the fan but have used the mgb one which has 7 fins
                Picture showing front mounted electric fan.
                This worked well in Le Mans and has proved itself in heavy traffic on the M25
                Hiya
                  I have the same Adrian, I am using the engine fan and mounted the electric fan on the outside to push air through as and when needed.
                    Found a nice pair of Westfield seats on eBay that will go nice in the Roadster.
                      Thought I would get her out in the sun today to give the garage floor a bit of a clean.
                        Wow she looks wonderful.
                          Thanks Adrian, paint isn’t perfect and still needs a bit of work.
                          None of the body panels are actually fitted yet just sitting in place.
                          Cheers, Martin.
                            You haven't seen mine in the cold daylight.
                            I'm just glad that I can drive her.
                            Carry on the good work and look forward to seeing you and the car in the very near future.
                              Well done Martin, looks really good. Must try and get over sometime, seems like ages.
                              If I can get all the concrete blocks out of my drive soon I might be able to get mine out of the garage.
                              Hugh
                                Great Job there
