Page 2 of 27 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 265
  1. #11 Re: Roadster Rebuild Diary from Cornwall
    frequent forum contributor Club Member jon_wilkinson's Avatar
    Mar 2016
    Macclesfield, Cheshire
    347
    Looking good.
    Keep them coming!
  2. #12 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    St Austell, Cornwall
    595
    Steering rack cleaned, checked ok and painted. Greased up and new boots fitted this evening.
  3. #13 Re: Roadster Rebuild Diary from Cornwall
    Oct 2016
    Armstrong BC Canada
    101
    Looking great Quality as good as can be
    Hi everyone,
    Thought I had better start on my rebuild diary as my roadster has been stripped to the bare chassis, wire brushed with angle grinder then a couple of coats of primer so far.
    Attachment 8223
    Ready for top coat.
    Attachment 8224
    I had an old barrel hanging around so thought that would make a good sand blasting cabinet, with a few bits removed from the skips at work, a pair of cabinet gloves purchased from eBay and I have my own cabinet.
    Attachment 8226
    In the mean time I have stripped the front suspension down and sandblasted the paint and rust off before primer and topcoat.
    Attachment 8225
    I started a thread a couple of weeks ago about a replacement master cylinder and servo but after a bit of TLC my original Marina/Ital one will be OK, looking through the vacuum hole the diaphragm looks to be in good condition. The master cylinder has had the same treatment with a new set of seals ready to fit. Before anyone asks, no I didn't sand blast the servo, I plugged up all the holes and wire brushed it.
    Attachment 8227
    Top coat on the chassis today.
    Attachment 8298
    I have also fully stripped the front suspension, repainted and replaced the ball joints, trunions, wheel bearings and caliper piston & seals. Next job is to start rebuilding the front.
    Attachment 8300
    I removed the rear brake drums to clean up and repaint and noticed a crack in one, has anyone seen these crack like this before?
    Attachment 8299
    How much time have I spent in the garage so far and I haven't even got anything bolted back to the chassis.
  4. #14 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    595
    Stripped the rear axle down and stripped the paint before repainting then new bearings and seals.
    From this. (Do you like my toy car road rug?)
    To this.
    Next it's getting the bulkhead, tunnel and rear bulkhead to be stripped of all old adhesive then bolted back in.
    Looking through the original build manual it will then be engine and gearbox back in, exciting times.
  5. #15 Re: Roadster Rebuild Diary from Cornwall
    Nov 2015
    Llandrinio
    164
    looking excellent!
  6. #16 Re: Roadster Rebuild Diary from Cornwall
    Club Member David's Avatar
    High Wycombe
    1,126
    That is all looking good, I'm feeling slightly embarrassed that I'm still working up the enthusiasm to re-visit my leaky choke mechanism... small job, but lacking enthusiasm to continue the saga. I should have returned the carbs as 'not fit for purpose' instead of deciding to correct the bad workmanship myself!
  7. #17 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    595
    Been busy today cleaning up the bulkhead.
    Before.
    After.
    And fitted to the chassis.
  8. #18 Re: Roadster Rebuild Diary from Cornwall
    frequent forum contributor Club Member andyf's Avatar
    Sep 2014
    Yateley, Hampshire
    678
    If you haven't already thought of it you should consider adding the bulkhead strengthening to stop it cracking.
  9. #19 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    595
    Thanks for that. I have got it and dug it out to be stripped and repainted.
    It is the triangle that bolts onto the servo mounting plate and bolts to the side louvred bonnet. Is this the best design or is there one that takes it down to the chassis?
  10. #20 Re: Roadster Rebuild Diary from Cornwall
    Sep 2014
    Yateley, Hampshire
    678
    It's the factory design that I think most people use. I used an old kart track rod and made a couple of brackets to fix it between the peddle box and the chassis. There are some pictures in my blog. I may have another track rod lying around, I'll have a look in the week.
  1. Replies: 0
  2. V8 Roadster rebuild
  3. Replies: 22
