Page 23 of 27 FirstFirst ... 13 21 22 23 24 25 ... LastLast
Results 221 to 230 of 265
  1. #221 Re: Roadster Rebuild Diary from Cornwall
    Bodmin, Cornwall
    703
  2. #222 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    St Austell, Cornwall
    511
    Ha, I like it.
  3. #223 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    511
    Finally my running boards and rear wheel arches are ready for paint.
    Lovely weather so will get the primer on tomorrow.
  4. #224 Re: Roadster Rebuild Diary from Cornwall
    High Wycombe, Buckinghamshire
    1,776
    Looking good.
    Great weekend for it.
  5. #225 Re: Roadster Rebuild Diary from Cornwall
    High Wycombe
    1,036
    1275 Marina based, my favourite. can't wait to see it finished
  6. #226 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    511
    Thanks and I also can’t wait to see it finished. :-)
    Lovely weather so got the primer on, get it flattened off then all I need is another weekend like this and I can sort the topcoat. Gets bleddy hot in the paint tent.
    Last to paint will be the headlight pods and the spare wheel carrier, nice small and easy bits then on to the brakes, fuel and cooling and all the other unfinished bits.
  7. #227 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    511
    Whilst having a bit of a tidy up in the garage I came across the radiator cowl that I took off the car nearly 3 years ago. It is stainless steel and after a bit of a clean up and slight modification to add the fan looks good.
    It was made to house the classic Mini rad so I ordered a new aluminium rad.
    My plan is to use the original engine cooling fan and also wire in the electric fan that is now fitted to the front of the cowl. The fan works in both directions so just need to make sure I wire it so it blows cool air through the rad rather than away from it. I can either wire it to a thermostatic switch or to a switch on the dash, thermo switch will probably be best.
  8. #228 Re: Roadster Rebuild Diary from Cornwall
    Bodmin, Cornwall
    703
    Are you mounting on the back or front of the rad. Martin? It's much better on the back as it impedes the natural air flow less.
  9. #229 Re: Roadster Rebuild Diary from Cornwall
    406
    I agree, mounting on the engine side is better. In addition it gets fewer insects stuck to it and makes cleaning the rad easier.
  10. #230 Re: Roadster Rebuild Diary from Cornwall
    2,929
    I don’t think it makes much difference, it will spin in the airflow anyway, and if needed it will turn on maybe a fraction earlier.
    There is a debate though that curve bladed fans are more efficient spinning in the correct direction.
    Two fans mounted in-line is likely to be a lot less efficient as the air flow from one is likely to cause the other to stall.
  1. Replies: 0
  2. V8 Roadster rebuild
  3. Replies: 22
