Page 24 of 27 FirstFirst ... 14 22 23 24 25 26 ... LastLast
Results 231 to 240 of 265
  1. #231 Re: Roadster Rebuild Diary from Cornwall
    High Wycombe, Buckinghamshire
    1,830
    Hiya
    I have mine mounted on the outside pulling air in.
    I have also kept the original fan as this allows for hot air to be pushed out via the shark gills.
    Will add a picture in a moment.
    I agree, mounting on the engine side is better. In addition it gets fewer insects stuck to it and makes cleaning the rad easier.
  2. #232 Re: Roadster Rebuild Diary from Cornwall
    1,830
    Note: I have retained the fan but have used the mgb one which has 7 fins
    Picture showing front mounted electric fan.
    This worked well in Le Mans and has proved itself in heavy traffic on the M25
    Hiya
  3. #233 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    St Austell, Cornwall
    552
    I have the same Adrian, I am using the engine fan and mounted the electric fan on the outside to push air through as and when needed.
  4. #234 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    552
    Found a nice pair of Westfield seats on eBay that will go nice in the Roadster.
  5. #235 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    552
    Thought I would get her out in the sun today to give the garage floor a bit of a clean.
  6. #236 Re: Roadster Rebuild Diary from Cornwall
    1,830
    Wow she looks wonderful.
  7. #237 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    552
    Thanks Adrian, paint isn’t perfect and still needs a bit of work.
    None of the body panels are actually fitted yet just sitting in place.
    Cheers, Martin.
  8. #238 Re: Roadster Rebuild Diary from Cornwall
    1,830
    You haven't seen mine in the cold daylight.
    I'm just glad that I can drive her.
    Carry on the good work and look forward to seeing you and the car in the very near future.
  9. #239 Re: Roadster Rebuild Diary from Cornwall
    Bodmin, Cornwall
    717
    Well done Martin, looks really good. Must try and get over sometime, seems like ages.
    If I can get all the concrete blocks out of my drive soon I might be able to get mine out of the garage.
    Hugh
  10. #240 Re: Roadster Rebuild Diary from Cornwall
    Club Member dcunn's Avatar
    1,339
    Great Job there
  1. Replies: 0
  2. V8 Roadster rebuild
  3. Replies: 22
