Page 3 of 27 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 265
  1. #21 Re: Roadster Rebuild Diary from Cornwall
    Bodmin, Cornwall
    731
    I put a piece of alloy angle from side to side across the top of the tunnel and pop rivited it top and bottom as a permanent fixture. I'll try and find a pic.
  2. #22 Re: Roadster Rebuild Diary from Cornwall
    Bodmin, Cornwall
    731
    Here we go, you can see it running along the fold.
  3. #23 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    St Austell, Cornwall
    599
    Thanks for the advice, I will have to find some angle aluminium and do the same.
    Did it interfere with the accelerator pedal fixing bracket?
  4. #24 Re: Roadster Rebuild Diary from Cornwall
    frequent forum contributor Club Member andyf's Avatar
    Sep 2014
    Yateley, Hampshire
    678
    I have something similar as well as the brace. I thiBK it should be fine. Mine is at the limit of what the studs will fit through.
  5. #25 Re: Roadster Rebuild Diary from Cornwall
    Bodmin, Cornwall
    731
    From memory, and it is a long time ago, no, there wasn't any problems and its been like that since 1990.
  6. #26 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    599
    Been stripping the bell housing off the gearbox today to clean up ready to paint. The first motion shaft oil seal was perished and gasket fell to bits so ordered a new set. Put the build wheels on and noticed I have got a camber issue as in the picture. I haven't taken any measurements yet other than one side is sitting 5 mm higher on the damper (centre to centre of mounting bolts) even though I set the outer ends of the suspension arms 150mm lower than the inner mounting so some minor adjustments to be made.
  7. #27 Re: Roadster Rebuild Diary from Cornwall
    Sep 2014
    Yateley, Hampshire
    678
    I wouldn't worry until you put the engine and box in as it will settle down then.
  8. #28 Re: Roadster Rebuild Diary from Cornwall
    Club Member dcunn's Avatar
    1,459
    Suggest as Andy says you wait a while. May even be better to wait until its all together then get in and and bounce it around a bit
  9. #29 Re: Roadster Rebuild Diary from Cornwall
    Jul 2016
    599
    Ok thanks will wait. I have a set of adjustable tie rods that I am going to clean up and replace the standard ones as well.
    As for a panhard rod in my other thread, do they help, would the RTL linkage be better? That looks a neat solution to the sideways movement of the back end. Has anyone fabricated one at home?
  10. #30 Re: Roadster Rebuild Diary from Cornwall
    SE London
    2,186
    In case you haven't noticed the bottom bolt in the bell housing has a copper washer and needs to go back in the bottom bolt hole.
  1. Replies: 0
  2. V8 Roadster rebuild
  3. Replies: 22
