Roadster Rebuild Diary from Cornwall
  • Re: Roadster Rebuild Diary from Cornwall
    I got an excellent finish on a classic dinghy using 2 pack pu and a roller(think it was supposedly a quality roller for varnish) - I realise a boat is a different beast but most of the surfaces are similar, just problematic with the louvres, but again a quality brush would probably achieve good results!
      Thanks for the replies. Think I will go for the cellulose, keep with what I know how to use.
      Cheers,
        My mobile paint shop, not ideal but it keeps the garage clean.
        What colour am I painting it? I will update later.
          In this weather it will work as a low bake oven as well, just make sure you use a filter mask especially if
          you are using self etch primers.
            Thanks Ben, I am using cellulose with a respirator suitable for solvent fumes.
            Anyway gone for Tornado red, just the scuttle at the moment. Just got to leave it for a couple of days then flatten off then out with the T-cut and polisher.
              Spent a good couple of hours today sanding the nose back to gelcoat. Ground out a couple of crazing spots then filled and sanded back.
              Just need to use some finer paper then ready for primer.
                Between the dumb iron tray and the nose used to collect water, so I drilled a hole on each side so now it drains. I dressed the holes with epoxy to seal them.
                  Thanks Dave,
                  Was thinking that as there was a thread a while back about drainage holes.
                  I have also glassed in a plate where the bonnet fixes to it.
                    Would be interested in where you will put the drain holes and whether you use round holes or a slit.
                    Originally posted by meverett View Post
                    Thanks Dave,
                      Where the water collects I drilled a round hole at about 45deg from horizontal ( after checking that there was nothing behind) then with araldite on a stick sealed the edges. Now water doesn't collect there.
                        Opted for a couple of slots, just got to seal the fibreglass edges.
                          Looks OK so will more than likely do the same
                          [ATTACH]10195[/ATTACH]
                            Spent a couple of afternoons last week stripping the paint off the side panels.
                            Nice weather this morning so decided to set up the paint tent and prime them and also the nose and the bonnet/windscreen trim.
                            Flatten them off in a couple of days ready for topcoat next weekend, weather permitting.
                              Looking good!
                                How did you cut the slots?
