I'm well underway with removing the old dash & all the switches and instuments but I have hit a hurdle on the final instrument - the oil pressure/water pressure gauge...
On the back of it there are two feeds, the first is for the oil pressure:
It has a plastic or nylon tube joining it which seems to be tightly fitted onto the brass spigot. At first sight, I thought, perhaps it has that hexagonal shape to allow one to put a spanner around it to tighten it on / loosen it off the gauge.. However not wanting to do it wrong first time I thought I'd better ask you guys that have been here before.. So - to remove the gauge from the old dash - do I simply undo/unscrew the hexagonal stud OR - do I cut the pipe and then remove the tube and to refit (eventually) do I just heat up the pipe and slide it over the spigot once more?
Question 2:
There is a water sensor wire that enters the gauge, it has a spiral wire protective sheaf running its entire length..
To remove this from the guage - does the lower brass sleeve simply unscrew?
Many thanks!
Question 2:
Many thanks!
