Thread: Members Map
Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 57
  1. #21 Re: Members Map
    Sep 2017
    Tamworth Staffs.
    223
    Being a new member I would be happy to be added to the members map. Is this not something that could be added to the membership application? Would you like your details added to the members map. Tick for yes? Or am I being too simplistic and lack background understanding? Happy to be advised........Steve
  2. #22 Re: Members Map
    Club Member stewartdjones's Avatar
    Shepperton, Surrey
    63
    Reading through the various comments on the subject I started re members map, can I suggest that it could a subject placed in Pitstop stating the yes or no and be a question at the next committee meeting and a subject in the any other business at the AGM.
  3. #23 Re: Members Map
    Administrator Club Member
    Nov 2016
    105
    Hi Steve,
    Welcome to the club.
    I have been following this thread with some interest but I don’t have an easy answer.
    As I recall the original members map was created after a pole asking members if they would like to be added to the map. The map was created from a list of members using that pole. I don’t have that list. The map is out of date but without the original list I can’t update the map to add or remove members. Even if the original list could be found I could add the new members but how to find out which members or ex-members still want to be in the map?
    As suggested the ideal situation would be to have a check box in the member’s profile to update the map automatically. This would require some bespoke code. We are reluctant to use bespoke code because it can be expensive and maintenance can be a problem. We may need to revise the code every time the associated software was updated.
    There are two more possibilities. We could make a member’s check box then manually extract a list of members opting in. Then rebuild the map by hand at regular intervals, say monthly or biannually. I have two concerns over this method.
    1) The original pole did not get a big response and I think asking members to update their profile would get a smaller response. It should be remembered that a large part of our members never logon.
    2) I would be creating more work for my successor. Once set up I anticipate it would be less than an hour’s work to renew the map. A way round this might be to have a volunteer become the Marlin Map Master.
    The second possibility is to add the details of all members in an anonymous way. Then if any member wanted to approach another member found on the map we would broker a contact. This is not easy as the map is created from the members name and address. It’s easy enough to change the name to some code. If we somehow disguise the address how useful is the map?
    Any of the above may incur additional cost with our web supplier. Would this be a good use of the club’s funds?
    So the question is not so much “yes” or “no” but “hope so”. This topic is discussed within the committee fairly regularly. It is not a lack of care that is causing delay but a lack of an easy answer. I think this will be discussed at our next committee meeting but I don’t see a simple way forward.
    We would welcome any other suggestions.
  4. #24 Re: Members Map
    3,148
    Quote Originally Posted by mocad2016 View Post
    How about another option.
    Each member, who wants to be included, makes that choice their own. And then give them the option of inputting as much information, or as little, that they are happy with, without approval from mocad2016, whoever he happens to be, apparently, Paul?
    Dispose of the need for web admin to add, I bet they never delete, data, reducing their admin input.
    Give each member the responsibility for their own data.
    If the map database fails, it will be the lack of members support that is to blame, and the project closes.
  5. #25 Re: Members Map
    Nov 2016
    105
    Hi Steve,
    I agree that there could be automation and that would avoid manual administration. But it would inevitably require some bespoke code and that is not an option for the reasons stated.
    Moccad2016 is the club administrator’s id, currently me (Paul Carey). I am trying to separate “official” communications from personal ones to aid the transition to a new administrator in May 2018.
    Contact details in the “contact us” web page and in Pitstop.
  6. #26 Re: Members Map
    High Wycombe
    1,125
    Just chipping in here because I noticed that the map is a Google Map and I know, because I’ve used these for other data, that all it takes is to upload a data file(spreadsheet) to get the pins on it. So if someone can do an export of the members list it’s a 10 minute job.
    Happy to help do this if someone is happy to give me the (edited, sanitized) data and access to the Google account that the map is attached to.
  7. #27 Re: Members Map
    Nov 2015
    Llandrinio
    164
    The map is simply a Google map with a CSV format list of members who opted in to it,as David states; it took no time to update but collating new map pins seemed to be a bit longwinded. I used to update it every two or three months. The idea of members updating their own pushpin is nice but pretty difficult. Paul is right too, in order to extract data from consenting members from the membership dB then port it into a mapping tool would require we one pair for coding. I do think a map is a good idea but it does require someone to actually get the data in at regular intervals. I think it is likely to be revisited by the committee soon (they are proactive!) So if anyone wants to volunteer for the Map Master job let Paul know in the first instance?
  8. #28 Re: Members Map
    3,148
    Can this option be investigated. It sounds plausible.
    https://www.vbulletin.org/forum/showthread.php?t=141584
  9. #29 Re: Members Map
    frequent forum contributor seasider790's Avatar
    Nov 2015
    Burnham-on-Sea
    40
    Assuming that most members would use the map to find out details of other members in a particular area (usually near to them I imagine), has anyone ever looked into the possibility of providing a "Search for other members by postcode" option? I've no idea whether this would be impossible or easy to set up, but it might be worth checking. In the year that I owned my Marlin, I only got to meet up with one other member who lived in Somerset, but it would have been great to have known if there were others within the county who would have been interested in a run out somewhere or even just meeting up for a drink and some "car chat".
  10. #30 Re: Members Map
    451
    Hi Steve,
    The big problem at the moment is to know who wants to be in and who’s out.
    The web site you pointed to is “Phoogle! An interactive Google Maps mapping system” a vBulletin 3.6 add-in. The program was released: 09 Mar 2007 and the last update: 09 Apr 2007. The author’s last activity was in 2012. We are on a newer vBulletin version. Even if the application was a perfect fit for us I could not implement unsupported code. A good thought though.
  1. Members Only
    By Dane_Rescueman in forum General Discussion
    Last Post: 01-10-2016, 08:46 PM
  2. How many members ?
    By trevor_ford in forum General Discussion
    Last Post: 30-11-2011, 10:21 AM
  3. Members or not members
    By keith_h in forum General Discussion
    Last Post: 11-05-2011, 09:40 AM
