Marina Based Roadster Upper Steering Column plastic bush
  • Marina Based Roadster Upper Steering Column plastic bush
    Hi all
    Is this the same bush as an early mini, as it looks the same?
    http://www.ebay.co.uk/itm/CLASSIC-MI...HMUz0M0XFsl-Uw
    Re: Marina Based Roadster Upper Steering Column plastic bush
    Yes as is the lower. Change both. Worth looking at the rubber joint, and the UJ at the steering rack end.
    I did a write up of the whole sequence at fast Marina, it's in their technical section.
