Leaking SU carb (float bowl lid - inlet pipe)
  • Leaking SU carb (float bowl lid - inlet pipe)
    The leak is really a slight weeping at the joint of the brass inlet pipe and the float bowl lid. I can't see any way to repair it. I have seen soldering / brazing kits that claim to be able to join aluminium and brass but I am a bit reluctant to try this in case I do more harm than good!
    It's a single 1-3/4" su on the marina 1800 engine
    I have tried http://sucarb.co.uk a bit pricey but the lid assemblies are out of stock anyway, and the usual ebay search hasn't come trumps yet
    Does anyone have any suggestions or a spare lid that that I can buy?
    Any help will be much appreciated
    Phil
    Re: Leaking SU carb (float bowl lid - inlet pipe)
    What fuel pump does the car have?
      It sounds quite unusual for the brass inlet to leak. First check the flexible hose, it may not be sealing because its old - chop an inch off and retry the join. It could be the hose clip isn't sealing the rubber flexible hose properly so you get a fine mist of fuel which gathers around the inlet pipe. My money would be on the flexi pipe, esp if its old and has been used with modern fuels.
      Second thing to check is the float valve and needle - if it sticks then the fuel can build up to such a level it leaks (though normally through the overflow or top gasket). A bit of crud from the rubber pipe or out of the tank can be all it takes - whilst you are at it examine the needle for ridges or wear.
      If on the other hand you can physically move the inlet then the lid is scrap. You could try bodging it with something like plastic padding metal but it will be a bodge. Good luck - let us know what you find.
        It is the standard Marina mechanical pump
          It's certainly unusual and has been driving me scatty!
          I have tried replacing the hose, hose clip and the float valve and needle
          Pulling the hose back from the face of the lid, re-sealing it and with the engine running a very slight weeping of fuel can be seen from around the inlet pipe and running down above the overflow/vent
          The inlet pipe itself as a dent in it so it must have taken a knock at some time in it's life and maybe that is the cause of the leak
          The pipe isn't loose and there must just be the smallest capillary leak in the join to the lid
          Epoxy gave a temporary fix but as you say it's a bodge, not satisfactory and only temporary anyway, but the fact that it did stop the flow confirmed the source. I guess that this is all I can do until I find a replacement
          Thanks for the suggestions and I will let you know how I get on
            A bit scruffy but the right price
              Try a local breakers yard, not many about now or Stuart Miles he breaks Marinas. 07517 62640. I have had gear from him, but not recently. At a push what diameter is it, I may have one in my box of useful bits.
                If you're still stuck contact me and I'll machine it out and fit a new spigot.
                Hugh.
                  Hi Hugh
                  I think I am sorted now with a replacement but thanks for the offer. If the replacement doesn't work out I will take you up on it
                    You're welcome.
                      Replacement lid fitted and the problem is now cured
                      Thanks for all the help / advice
                      Phil
                        Well done now that your fixed you could have a go at sweating in with solder the old one, if it works you have a spare if it don't nothing lost really.
