Wheel Centres
  • Wheel Centres
    Hi Folks,
    I'm new to the Marlin Owners Club, though I have owned my roadster for 27 years! I've just refurbished it from top to bottom and am adding some finishing touches. It's a Triumph GT6 based front end with GT6 engine and overdrive gearbox coupled to a Marina back axle. I've fitted MGTF alloy wheels after replacing the original studs with 12mm upgrades. I'm delighted with the look but of course they have MG wheel centres. I recently bought some Marlin wheel centres to replace. Can anyone advise what glue works to fix them before I start.
    Cheers Tony Ellis
    Re: Wheel Centres
    I used evostik contact adhesive. Holding so far.
      Re: Wheel Centres
      Thanks Jon, much appreciated. Tony
        Re: Wheel Centres
        Ditto
        Stumbling around in the dark
        Marina based SWB roadster
          Re: Wheel Centres
          Another ditto
            Re: Wheel Centres
            Hi Tony I have sent you a PM click notifications at the top of the page.
              Re: Wheel Centres
              I would like to see the design of your spacers, presumably concentric and not just relying on the M12 bolts for location.
                Re: Wheel Centres
                Originally posted by Blue Marlin View Post
                Ditto
                Another ditto - but I bought four and forgot the spare needed one!
                  Re: Wheel Centres
                  Yup when I got my Marlin it had non concentric spacers fitted - not only poor alignment but wheel balancing was tricky and could change when wheel taken off and refitted. Plenty about it on line as I had never heard of teh issue until my tyre place mentioned it when Ihad muy wheel balanced. Proper ones also included me fitting longer wheel studs as oringinals were clsoe to too short.
                    Re: Wheel Centres
                    PS to all those who read my posts I have finger dyslexia on the keyboard - but eonugh of teh lettres ruffly in the write order to gt the drift
                      Re: Wheel Centres
                      Just to zay dat dudes can edit der own posts. – if required.
                        Re: Wheel Centres
                        to lazy
                          Re: Wheel Centres
                          Hi Steve
                          I am thinking of ordering these rims for my Marlin http://www.johnbrownwheels.com/produ...minilight.html they are 15x5.5 with 4x95.25 ped with +15 offset but are not concentric will I be having problems with these rims?I am thinking the deep wheels nut should center things fine.
                          Michael
                            Re: Wheel Centres
                            Originally posted by michael47 View Post
                            Hi Steve
                            Michael
                            first thoughts.
                            Avoid wheels that are not concentric, the Marina studs/lugs are not strong enough.
                            The standard offset is 1/2”. With a 185 profile tyre there is adequate clearance between the tyre and the steering arm though some tyres are wider.
                            Much of the handling of a Roadster relies on tyre wall deflection the reason many people use 20psi or there about.
                            Low profile tyres may look pretty cool but they inevitably result in a harsher ride.
                            There must be a classic alloy wheel supplier in Vancouver, try the Triumph car community.
