Thread: On going rebuild
Results 1 to 7 of 7
  1. #1 On going rebuild
    Feb 2017
    Birmingham
    38
    Good evening all
    Well my Marlin has come a long way from my last posting, the Engine is completed the Gearbox is now back together and ready to fit.
    I have managed to get the first coat of paint on but plan to flat it down with 1200 grit and blow another coat over, I have redesigned some bit
    that was in need of attention and I have fitted a whole new bulk head and top deck.
    My wiring harness is now looking much better, the rear axel has been refitted and fully polly bushed. I have also bonded some sound deadening
    matting in the car,
    Now teaching is over at the college I work at I can dedicate myself to getting the car back on the road.
    have included some pictures for you to view.
    Darth Vader
    Mike20170709_123235.jpg20170714_094849.jpg20170714_094900.jpg20170714_094910.jpg20170714_194119.jpg20170714_194130.jpg20170715_003326.jpg
  2. #2 Re: On going rebuild
    frequent forum contributor Club Member andyf's Avatar
    Sep 2014
    Yateley, Hampshire
    678
    Looking good
  3. #3 Re: On going rebuild
    frequent forum contributor Club Member jon_wilkinson's Avatar
    Mar 2016
    Macclesfield, Cheshire
    347
    I see you are using one of those aluminium Civic radiators. Would you be able to post a photo of the mounting brackets you have used, please? I'm thinking of using one to replace my current leaky rad and it's always helpful to see what others have done rather than reinventing the wheel.
  4. #4 Re: On going rebuild
    Feb 2017
    Birmingham
    38
    Greetings
    you can probably see from the second picture, just infront of the cross memeber the origonal builder welded two lengths of 25mm X 2mm angle iron. at the bottom of the cross member two lengths of 25mm X2mm flat iron have been welded on and drilled to suite the fixings on the bottom of the radiator.
    hope this helps, if you wish I can take pictures and send them on to you.
    darth vader
  5. #5 Re: On going rebuild
    Mar 2016
    347
    Thanks DV, I see those now.
  6. #6 Re: On going rebuild
    frequent forum contributor Club Member 928cdu's Avatar
    Jul 2016
    Warwick
    144
    Very impressed Mike, should be a great car when done..
    Regards .. Richard
  7. #7 Re: On going rebuild
    Feb 2017
    Birmingham
    38
    Afternoon
    Thanks, I am having a few issues with some Micky Mouse bits that have been added in the cars past but slowly working my way through.
    will post an update in a few days when a lot more should be completed.
    Darth Vader
  1. Mk1 rebuild video
    By b_caswell in forum Roadster
    Last Post: 27-12-2016, 04:39 PM
  2. Mk1 Rebuild for Second Honeymoon!?!?
    By IDM in forum Build and Rebuild Diaries
    Last Post: 20-11-2016, 09:34 PM
  3. Rebuild Inspiration
    By IDM in forum General Discussion
    Last Post: 12-07-2016, 11:15 PM
  4. V8 Roadster rebuild
