Cabrio door lock release cable.
  • Cabrio door lock release cable.
    Hi everyone,
    I am in desperate need of a door lock release cable.
    Have tried breakers, e-bay, and even Ford! with no luck.
    It needs to be approx 72 cm long.
    Will other ford cables fit?
    Any advice appreciated.
    Regards Mike
    Re: Cabrio door lock release cable.
    Can you either make a replacement using a bike brake cable or join in a section of new cable with solder less joiners use the inserts that are in electrical choc blocks.
      I used a cable from at 2 door fiesta, got it from a scappy. The fittings are the same ( it was probably a 1990 Fiesta)
        Originally posted by mike woodley View Post
        Hi everyone,
        Regards Mike
        Mike I have one which side do you need as its complete with handle
          Hi Peter,
          Its the drivers door lock cable that's gone (offside)
          If you want to ring my mobile is 07763213288
          Regards Mike.
            Hi Peter,
            Regards Mike.
            Off to the post office with the cable
              This is a bit of a minefield as there are several variables. Firstly, LWB Cabrios require longer cables as the doors are 2" longer than SWB. The cables came in several lengths depending on fitment - saloon, estate, front, back, etc - and were on Mk 2 Sierras (Mk 1 had different handles and used rods). The same type of door furniture was also used on other Fords of the time - Fiesta, Escort, Granada - so they are also sources of these items, and even more variety in cable length.
              Have a look at the earlier thread 'Cabrio Door Locks' from 17/8/16 for more info. Dave
