Originally Posted by
phil.coyle
Hi Dave,my apologies for inadvertently hijacking your thread, a word of caution! If you have marina front suspension at the moment, think about where the steering rack will go. Marina racks sit behind the axle and cannot be used in front of it. Check where your steering arms will be ,front of the axle or the rear.
If you swop the uprights from side to side you will have problems with king pin inclination and self centring . This titbit will save you some research time: Ford Escort mk2 is an almost perfect fit in front of the axle, and can be adjusted by steering rack extensions, simple internal threaded tube.
