Results 1 to 2 of 2
Thread: Fuel Tank Sender
  1. #1 Fuel Tank Sender
    Nov 2016
    Oxfordshire
    15
    Just got myself a nice little Hunter for the summer (the Berli is a long term project) and I believe that I need to change the fuel tank sender. Will check that it's not the wiring first BUT what sender should I buy? Believe it is off a Sierra, but what model. Thanks
  2. #2 Re: Fuel Tank Sender
    1,093
    The Hunter was fitted with after market petrol sender matched to the instrument. Remove it first and take a look and test it. The instruments were a Stewart Warner product at first and if this is the case then Merlin motorsport on Castle coombe were the supplier at one time. Marlin should be able to confirm this. The running gear etc on a Hunter are Sierra/ Granada etc but the complete wiring loom/ instruments/ senders etc were all custom made and fitted new.
Similar Threads
  1. Smiths Fuel Gauge To Tank Sender
    By timmacx in forum Roadster
    Last Post: 28-11-2020, 09:32 AM
  2. Replacement fuel tank sender?
    By b_caswell in forum Roadster
    Last Post: 13-12-2018, 10:21 PM
  3. Fuel Sender Tank Gasket
    By greyV8pete in forum Cabrio / Hunter
    Last Post: 03-03-2013, 10:38 AM
  4. Fuel Tank Sender Unit
    By amalgamated users from prior forum in forum Sportster
    Last Post: 10-07-2006, 10:55 PM
  5. Fuel tank sender/pickup Berlinetta
    By cabrioman in forum Berlinetta
    Last Post: 15-04-2005, 12:25 PM
