Thread: Windscreen
Results 1 to 6 of 6
  1. #1 Windscreen
    Leeds
    282
    Does anyone happen to have had a new windscreen lately for their Cabrio and if case where did they source it from.
    I need one for my car and thought I would try and save some leg work before I start ringing round the usual suspects to try to find someone who can cut me one.
    Happy for it to be supply only or supply and fit.
    John
  2. #2 Re: Windscreen
    212
    Hi John
    I summarised my windscreen experiences in Pitstop 194, and probably on the forum too. The upshot of it was that the insurance company gave me the number of Auto Windscreens, and they then said they could not cut laminated glass or fit to non-standard cars. Hmmm! I eventually got in touch with Specialist Glazing Services (Halifax) Ltd (aka Halifax Windscreens) on 01422 361063 who could not have been more helpful. They came to my house in Bradford, removed the old screen, cleaned & primed, and cut & fitted the new one, quickly and at reasonable cost. As you are in Leeds, they should be able to sort you out. Anyone further afield could also ring them as they may be able to give you someone more local - I think they may be part of a larger group.
    Just recently, I was going through some old papers relating to the build and I discovered the sticker from the original (Marlin supplied) screen. Guess who the original suppliers were? In one, Auto Windscreens!!! Methinks they suffer with a&e disease! (e stands for elbow). For what it is worth, the info on the sticker was as follows:
    MODEL HT 9859 LGR
    LW 9859 T90
    ORDER BSG 11432
    REF A 12561 B 100396
    It makes no sense to me, and I suspect it will make no sense to them either!
    Good luck - Dave
  3. #3 Re: Windscreen
    Club Member dcunn's Avatar
    1,463
    Contact your local Auto Windscreens
    Two years or so ago their man cut me one (from a Land Rover screen?????) but don't forget you need the etched markings on it
  4. #4 Re: Windscreen
    Nov 2015
    Llandrinio
    164
    An alternative if you don't need the E marking is to contact a plant glass firm (tractors and digger glass type) who often have flat sheet of the correct type.
  5. #5 Re: Windscreen
    Leeds
    282
    Quote Originally Posted by dave_kitson View Post
    Hi John
    MODEL HT 9859 LGR
    LW 9859 T90
    ORDER BSG 11432
    Good luck - Dave
    Cheers Dave Iíll give them a call.
    John
  6. #6 Re: Windscreen
    Aug 2015
    19
    Hi Cabrioman
    Did you have any luck with finding a new windscreen for your Cabrio ?
    I need one with the e marks etc for IVA
    Nigel
  1. Windscreen
    By paul in forum Cabrio / Hunter
    Last Post: 20-03-2020, 09:42 PM
  2. windscreen
    By ruby131 in forum Roadster
    Last Post: 29-02-2012, 03:58 PM
  3. windscreen
    By FranklinLeicester in forum Roadster
    Last Post: 11-12-2009, 09:31 AM
  4. windscreen
    By trevor_ford in forum Roadster
    Last Post: 05-08-2008, 03:59 AM
  5. Windscreen
    By Peterx in forum Sportster
    Last Post: 11-03-2008, 05:08 PM
