What battery
  • What battery
    Have had to replace the battery on the hybrid with Triumph bulkhead and the battery sits behind the heater.
    Using the ref numbers from the existing I bought a direct replacement different make. Problem is its just that bit taller and the posts will come into contact with the bonnet.
    Any suggestion or other application ref etc would be appreciated.
    Re: What battery
    Hi Ben,
    Try Tanya Batteries. The link below is a tool for putting in the size of your battery, etc, and it'll give you all the batteries that should fit. I've used them and the service was very good. Quick delivery. Think I got the link from an earlier post on this site??
    Gareth.
    Use our battery wizard to determine the correct battery for you. Simply enter dimensions and optionally terminal type and terminal layout to be presented with matching batteries.
      Re: What battery
      I had a the opposite in that when I bought a replacement battery using the reference number it was shorter than the original. I had a Varta and replaced it with a Lion from ECP. Perhaps you could check there.
      Stumbling around in the dark
      Marina based SWB roadster
        Re: What battery
        I bought a battery from Tayna & their service was 5*; nothing less than perfect.. the battery was not for the Marlin though..
          Re: What battery
          +1 for Tayna.
          I ended up with a Caterham battery as a replacement for an RMD item.
          Would never have thought about searching under Caterham without the ability to search by size and post-type on the Tayna website.
            Re: What battery
            +2 for Tayna
            Bought several from them and can't fault their system and service.
              Re: What battery
              Hi Ben, I recently (OK two years ago) purchased one from Halfords that fitted my Triumph based Roadster just fine .. if want to go down the conventional route , I'll find the model no.out for you ? It was rated for a Vitesse I'm pretty sure.
              Although I'm sure the suggestions above would be even neater.
                Re: What battery
                +1 here...
                  Re: What battery
                  I have always used Battery Megastore Tewkesbury
                    Re: What battery
                    Should have asked before getting involved with the local motor factors, so thanks for the suggestions but
                    to avoid a credit note I finally went with a compromise that I hope will work. The replacement battery will fit
                    but the posts are reversed so will have to play with the leads tomorrow Fingers crossed.
                    Thanks Chaps
                    Ben
                      Re: What battery
                      I have always used[ over the past 8 years the local small battery maker/shop who are always willing to check your battery whilst in the car, also alternators, starter motors etc and do a very quick and reliable rebuild service. They make their own batteries and make sure the battery posts are on the required side, and also whether they are at the front or back. The shop is a small family run father and son firm, Bridgwater Battery Centre, David.
