Roadster heater
  • Roadster heater
    I’m at the point in the rebuild that I have to think about installing the heater and matrix before finally fitting the dash and scuttle.
    Looking at the classic mini heater at the moment unless anyone else knows a better fitting one.
    Cheers, Martin.
    Re: Roadster heater
    That's what I used originally.
    It is quite bulky though & not hugely impressive. I eventually swapped to an early version of this...not a massive improvement in output but a little quieter and much more compact.
    Also had great service from T7, and I believe they are the manufacturers for a some of what Europa et al stock.
      Re: Roadster heater
      I went for this, small and excellent output.
      Since 2009, T7Design have grown to be a key brand in offering thermal solutions, efficiency and performance products to the Motorsport and Automotive industry. Alongside our own ever-expanding brand of Honda K-Series performance parts and a variety of both water fed and completely electric lightweight Heaters, we stock some of the worlds leading Automotive brands. A selection of engineering services can be provided to assist you with your ongoing projects such as 3D Scanning, 3D Printing and CAD Design. Whether you require a bespoke heater, fuel fittings, technical support or even a single titanium bolt - we have you covered.
      Cheers, Martin.
        Re: Roadster heater
        Great thanks, I will look into these.
        Cheers, Martin
          Re: Roadster heater
          I also purchased this
          https://www.t7design.co.uk/products/...eater-12v.html
