Thread: Sportster hood front frame fitting
Results 1 to 3 of 3
  1. #1 Sportster hood front frame fitting
    forum contributor
    Jun 2018
    9
    Hi I'm new to Sportster & have just bought one with a hood. There is a mushroom shaped fitting on the top of the screen that lines up with the split hood frame but I can't see any way to secure the hood to the screen as at the moment it isn't secured down. Am I missing a piece some where or doing something wrong?
  2. #2 Re: Sportster hood front frame fitting
    342
    Congratulations on getting a Sportster, I'm sure you are going to enjoy it!
    I don't think you are missing any parts.
    If you remove the pins at each end of the hood cant rail and lift each end up, you can slot the 'middle' ends under then the mushroom shaped peg. (You might need to unpop the hood at the back to do it). Then just fold the ends down and re-insert the pins. (It's a lot easier to do than describe in words!!)
    Here's a picture from inside the car.....
    Hood fitting by Sabrebuilder, on Flickr
    And here is a picture of one of the pins......
    I hope that helps?
    ...peter
  3. #3 Re: Sportster hood front frame fitting
    forum contributor
    Jun 2018
    9
    thanks Peter will try that. hood has been folded for a long time so need some tlc but it was just in case it rained as I was bring the car home as its a few days journey
  1. Folding Hood Frame
    By Cabrio_Simon in forum Roadster
    Last Post: 22-02-2013, 04:08 PM
  2. Sprtster Hood frame
    By Peterx in forum Sportster
    Last Post: 02-05-2009, 07:47 AM
  3. Hood frame
    By marks in forum Cabrio / Hunter
    Last Post: 10-12-2006, 06:31 PM
  4. Hood frame.
    By macdonald.dm in forum Berlinetta
    Last Post: 22-06-2006, 08:19 AM
  5. SWB hood and frame
    By daniels917 in forum Roadster
    Last Post: 13-06-2006, 03:04 PM
