Roadster windscreen frame.
  • Roadster windscreen frame.
    Hi, quick question. I am about to drill up into the windscreen frame to fit a dangly rear view mirror and was wondering if the frame is hollow or solid? Nothing else is attached tothe frame for reference.
    Derek
    Stumbling around in the dark
    Marina based SWB roadster
    Re: Roadster windscreen frame.
    Hollow. Be careful. If you do break the glass send me a pm and we can talk.
    Derek
      Hollow as Adrian says, quite a surprise to me as original docs suggest it's a roll bar. Hardly seems strong enough.
      It makes me think that modern adhesives might be a better safety option than drilling holes. But I can't say I have heard of an accident where the screen surround has prevented an injury though.
        Solid except for the slot for the glass. I've drilled several holes into it and tapped them, just don't break into the glass channel.
          That's strange when I drilled to put my wing mirrors on I was only able to tap around 1/8" and then air
            My Roadster frame was solid. But be careful!
              Definitely solid with a slot. Not hollow.
                The plot thickens
                  Does not the box section of the A post merge into the solid screen surround...so it might depend on how low you mounted the mirrors..?
                    There you might be right.
                    P.s. always ready to learn. Not an expert.
                      Thanks for the replies. I had always believed that the frame doubled as a roll bar and would be solid. I think I'll place it safe and use a 2 pack epoxy adhesive for the mirror. It's not heavy anyway.
                      Derek
                        Why not just use a mirror with the double sided mounting pad onto the glass.
                        Free Shipping, Classic Rear view mirrors,  Mirror glass replacement, Adjustable arm for interior mirror, Mirror arms, Mini interior mirror, replacement mirror heads, Anti-dazzle interior mirror "E" marked, Dipping mirror.
                          This my attachment, M3 screws. Latest is my dashcam, again M3
                            Sticky ones drop off
                            drilldupwards - solid - best solution
                              No they dont if they are applied correctly mine has been on there for best part of twenty years or so
