Radiator grill wire
  • Radiator grill wire
    Hello
    I am looking for Radiator grill wire already made
    thank you
    Re: Radiator grill wire
    I have one that is not made.
    Originally posted by kolmershlagjp View Post
    Hello
    thank you
      Oh forgot to add I also have the wooden block pre-drilled to make grill.
        is it all finished with the metal outline
          I have one that requires a little TLC. You can have it for postage cost. If you are interested I can dig it out and take some photos.
          Stumbling around in the dark
          Marina based SWB roadster
            Mine has a separate set of wires in a buddle as supplied by Marlin, a surround in the correct shape and a wooden base so that you can platt the wires.
            I hope that helps.
              yes, I want to see some pictures
              what does TLC mean?
                Tender Loving Care
                A little work to restore.
                  ok I understand I want pictures thank you
                      I remember spraying mine with a silver enamel rattle can (aerosol) when it started to look old. Lot of wasted paint obviously but result was ok ! They're not easy things to polish up.
                        Frame with wire and instructions
                          Hello
                          listerjp blue marlin i sent you a pm
