Thread: Drive shafts
Results 1 to 10 of 17
  1. #1 Drive shafts
    Club Member stewartdjones's Avatar
    Shepperton, Surrey
    63
    My kit (Marlin Cabrio LWB) is based on a Sierra 2l GLSi fitted with discs all round, looking for somewhere where I can get the drive shafts reconditioned or new ones, all ideas out there
  2. #2 Re: Drive shafts
    Mar 2013
    Fife, Scotland
    552
    https://rover.ebay.com/rover/0/0/0?m...2F132213135653
    I got Sierra drive shafts and CV joints from this company on ebay. Beware that there are at least four different lengths of shaft (Granada are similar but slightly longer, also left and right differ in length). There are also push in or bolt on CV joints. Scott.
  3. #3 Re: Drive shafts
    Exeter
    1,202
    Also be aware that the bolt on Lobro Sierra ones are 100mm diameter whereas the cosworth are 108mm!
  4. #4 Re: Drive shafts
    Moderator Club Member
    Derby
    1,375
    I also bought complete shafts from the same company as Scott for my last Cabrio . Good price and the quality seemed to be ok.
    As already stated be sure to get the right lengths.
  5. #5 Re: Drive shafts
    Shepperton, Surrey
    63
    How do measure to get the correct length?
  6. #6 Re: Drive shafts
    Sep 2017
    Saundersfoot West Wales
    96
    CPS- Drive link in Gateshead make _drive shafts in the UK and also sell imported Chinese shafts similar to those sold on E Bay
  7. #7 Re: Drive shafts
    Mar 2013
    Fife, Scotland
    552
    Quote Originally Posted by stewartdjones View Post
    You will probably find that the shafts are fine and any wear is in the joints themselves. So I would suggest that you remove the shafts from the car and dismantle them. Then you can check the shafts for wear, and if you still want new ones you can measure them. I made the mistake of assuming that if I purchased complete shafts and joints it would save me faffing about assembling them, but they arrived as a kit. So with hindsight I would have only purchased joints and boots. Scott.
  8. #8 Re: Drive shafts
    May 2017
    Exmouth
    10
    Hi, a recent MOT revealed that the CV gaiters on my Cabrio are showing signs of failure, although the CVs are probably OK.
    Has anyone had experience of fitting new gaiters without dismantling the shafts? The adverts suggest it is possible, but it doesn't look easy.
  9. #9 Re: Drive shafts
    79
    You could always try sierrasrus.co.uk
  10. #10 Re: Drive shafts
    968
    Hi Geoff There is a kit you can buy with split gaiters and an( epoxy type glue ) to solvent weld that are pretty good if you do not wish to strip the shafts.
  1. Triumph drive shafts...
    By David in forum Roadster
    Last Post: 27-09-2018, 01:43 PM
  2. Cabrio drive shafts
    By dogoncrazy in forum Cabrio / Hunter
    Last Post: 06-10-2016, 07:23 PM
  3. Hubs bearings and drive shafts
    By sam.pej in forum Cabrio / Hunter
    Last Post: 03-07-2011, 09:46 PM
  4. Half shafts
    By jimbounden in forum Roadster
    Last Post: 12-09-2010, 06:43 PM
  5. Marina drive shafts
    Last Post: 12-02-2006, 12:29 PM
