Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Flasher unit for indicators
  1. #1 Flasher unit for indicators
    club member Club Member element's Avatar
    Dec 2015
    Crieff, Perthshire
    271
    One problem gets fixed only for another one to take its place...
    My indicators have stopped working. It is a new switch unit , barely 6 months old. Everything worked fine until I got caught in a downpour (which may or may not have been a coincidence) in Glasgow. I have checked 5 of the 6 bulbs and all are good so far, working on the last one. I haven't checked the green dash bezel light bulbs; I'll do those too yet. I am beginning to suspect it might be the flasher unit; it is probably nearly 40 years old and most other parts have either been replaced or are showing signs they ought to be, I have the Haynes Marina handbook but although it describes it, there's no photograph & I don't know what it would look like. I imagine its in the relay block in a really awkward place to get to as I can't remove the dash... My plan is to follow the wires through the loom and see where they go and keep checking until I find where and why the circuit is no longer live... All the feed and return wires to all 6 bulbs are pretty awful. They ought to be replaced with new wires and I might just do that as I know it'll bite me one day if I don't.
    Coming back from Glasgow to turn or bear right I had to stick my right arm out and the Mrs did likewise for left..
    2002 Marina based LWB Roadster with Fiat 2.0 TC engine & box
  2. #2 Re: Flasher unit for indicators
    Dec 2015
    Crieff, Perthshire
    271
    https://www.ebay.co.uk/itm/VE725020-...Model%3AMarina
    My Dad did say today that he thought it was round cylinder shaped... Hmm.
  3. #3 Re: Flasher unit for indicators
    Jul 2016
    St Austell, Cornwall
    629
    If its the original Marina wiring loom then you should have a flasher unit for the indicators and one for the hazards, as in the pic below.
    I am installing a new wiring loom from PWS and the flasher is an all in one relay type so these are surplus, dont know if they work though.
  4. #4 Re: Flasher unit for indicators
    Jul 2016
    629
    Do you have hazards?
    The old school turning signals. Right arm out for turning right and right arm waving up and down for turning left.
  5. #5 Re: Flasher unit for indicators
    May 2016
    152
    You can use either the rectangular flasher units or the round tin can and just not use the third terminal on it, same as on the early mini's. If you have a hazard warning switch fitted they are notoriously troublesome . So after checking& rotating your glass fuses in the holder . Next carefully move the connector at the back of the hazard switch. I say carefully, because they can easily come apart and a spring and copper contact can then fly out. Also adjust the position of the rocker, as there are contacts inside that get pitted and they will then interrupt the indicator circuit.
    Fortunately with a Marlin Roadster if you have the roof off, you can point with your left arm arm left, as the car behind would see you ok.
    Hope that helps
  6. #6 Re: Flasher unit for indicators
    Dec 2015
    Crieff, Perthshire
    271
    I never even thought about trying the hazard switch! That seems an obvious idea!
    I'll do it tomorrow morning...
  7. #7 Re: Flasher unit for indicators
    Dec 2015
    Crieff, Perthshire
    271
    Hazard switch works fine, all lights flashing.
  8. #8 Re: Flasher unit for indicators
    May 2016
    152
    Well if your hazards work , the bulb & wiring surrounding them are ok.
    I have had with mine that when you switch them off, the switch needs an extra push so as to make the contacts work for the indicators, so give that a try.
    The next things to try are:
    1)You can test the indicator flasher unit off the car by connecting it to a 12v positive via a 21w bulb and earth the other terminal to the negative supply.
    2) alternatively photograph the wire order on each relay and swap the indicator & hazard relay around and see what you have.
  9. #9 Re: Flasher unit for indicators
    club member Club Member b_caswell's Avatar
    SE London
    2,220
    Waving up and down was slowing down,
    rotating the hand clockwise on an extended right arm was turning left,
    holding your hand upright in front of you indicated to a Police Officer on Point that you was going straight ahead.
  10. #10 Re: Flasher unit for indicators
    3,399
    Have you found your flasher units yet. The chances are that both of them are in the immediate area of the steering column area as they were on a Marina.
    Both look similar. Check which one is the Hazards by turning them on, and feeling for the click.
  1. My flasher won't flash
    By andyf in forum Roadster
    Last Post: 17-06-2017, 06:41 AM
  2. LED Flasher Lamps
    By greyV8pete in forum Cabrio / Hunter
    Last Post: 05-11-2015, 06:11 PM
  3. Flasher unit query
    By FranklinLeicester in forum General Car Chat
    Last Post: 26-04-2013, 07:05 PM
  4. Headlamp Flasher
    By stewartdjones in forum Cabrio / Hunter
    Last Post: 19-11-2007, 12:29 PM
  5. Flasher rate
    Last Post: 10-03-2006, 10:47 AM
