Thread: Roadster front lower damper bracket (Marina)
Results 1 to 10 of 11
  1. #1 Roadster front lower damper bracket (Marina)
    Nov 2015
    West Vancouver Canada
    19
    Does anyone have a spare pair? Or perhaps know where they can be sourced?
  2. #2 Re: Roadster front lower damper bracket (Marina)
    3,223
    Quote Originally Posted by cryophile View Post
    Pretty simple to get a Metal Basher to fabricate them locally.
  3. #3 Re: Roadster front lower damper bracket (Marina)
    Bodmin, Cornwall
    734
    Do you have one as a pattern? Or need dimensions?
  4. #4 Re: Roadster front lower damper bracket (Marina)
    SE London
    2,192
    There is a drawing from the late build manual fig 6 should help I think you could make it in two pieces each with its own flange if there is enough room between the wish bone parts after grinding off the boss.
    But my knowledge of Marina front end is limited,
  5. #5 Re: Roadster front lower damper bracket (Marina)
    SE London
    2,192
    Tried to post the drawing but failed sorry
  6. #6 Re: Roadster front lower damper bracket (Marina)
    Jul 2016
    St Austell, Cornwall
    608
    These what you are looking for?
    Some more parts in my parts bin. Canít remember why the holes are not the same on each, must have been odd bottom wishbones.
    If you can or know someone that could fabricate a pair for you, PM me your email address and I will send you some drawings to scale.
    Cheers, Martin.
  7. #7 Re: Roadster front lower damper bracket (Marina)
    Jul 2016
    608
    Scan taken from the build manual.
  8. #8 Re: Roadster front lower damper bracket (Marina)
    Nov 2015
    19
    Have a set, installed, but a friend wants a pair to upgrade a marina suspension. Lever dampers are a dying breed.
  9. #9 Re: Roadster front lower damper bracket (Marina)
    Nov 2015
    19
    Yep, these are the ones. Odd hole is the one you have to drill so someone might have mistaken the measurement.
  10. #10 Re: Roadster front lower damper bracket (Marina)
    3,223
    Ah, now we know what you really want. The late Marina/Itals were factory supplied with a telescopic front damper. There were kits of parts that could be fitted.
    The dampers were not mounted in the same manner as the Marlin, but offset from the lower arm by a bolt on bracket.
    There are still lever arm refurbishers for the old classic cars but I have not heard of one active for the Marina/Ital for years.
    You would do better asking the Morris Marina Owners Club or on the forum Fastmarinamagazine.com
    Somewhere I have pictures of the relevant home built brackets, I will try to find them later.
    One resource in the US that might be able to help you is a Facebook group, Austin Powerless Racing.
  1. front lower suspension arms
    By djj_engineer in forum What did you do with your Marlin today
    Last Post: 26-11-2016, 03:18 PM
  2. Marina based Roadster front discs
    By stevejgreen in forum Roadster
    Last Post: 03-01-2014, 09:25 PM
  3. Marina 1275 engine bracket
    By FranklinLeicester in forum Roadster
    Last Post: 03-10-2011, 12:27 PM
  4. Wanted: Front Offside caliper bracket
    Last Post: 08-10-2010, 08:44 AM
  5. Front lower ball joint.
    By macdonald.dm in forum Berlinetta
    Last Post: 27-09-2008, 02:23 PM
