cycle wing brackets.
  • cycle wing brackets.
    Hi all Martin Everett sent me email wanted some photos of my car front cycle wing brackets, took some photos, not very good, trying to put photos on,
    Re: cycle wing brackets.
    Hi Ray,
    Photos are not displayed.
    When you reply click the button as highlighted in the picture below the choose file.
    Cheers, Martin.
      Hi Martin does the one photo show in this thread? regards Ray.
        No Ray, it only shows as the words attachment 10455.
          I hope you succeed with the photo down load as I am very interested in options for cycle wing.
            Ray, when you post a reply bottom right "Go advanced" Click on that then scroll down to "Manage attachments" Scroll down again to manage attachments and a new window will come up. Top right browse to select your file then click Upload.
            Hope this helps, Hugh
              There is more help on how to add pictures in this thread:
              Good luck. If all else fails email me the picture (address in the magazine).
                IMG_20180926_140310[1].jpgSomething I did to secure the brackets to the mudguards that I think is transferable
                  Hi all still trying to add photos to this thread, (very trying), when I do get them on I have disc braked upright not sure what it is? the wing stays are welded to the upright 16mm tube flat plate on ends to rubber mount the cycle wings,CIMG0352.JPGCIMG0351.JPG
                    Hi should have pics now? can anyone tell me from the photos what upright I have please got lots of info with the car but not that? regards Ray.
                      Hi
                      Looks very much like it's from a Morris Marina.
                        Hi
                        Agreed...
                          Ray, success, pictures uploaded.
                          Yep it’s Morris Marina or Ital.
                          I understand now I see how the cycle wings are mounted.
                          The disc protector plates have been removed and a bracket welded on, a bracket also bolted behind the steering tie rod arm thingy and the mounting frame has been fabricated to fit these two brackets.
                            Hi thanks for all the info glad I know what it is now, many thanks, and photos yes result, regards Ray.
