Thread: Lights!
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
  1. #11 Re: Lights!
    Exeter
    1,155
    Quote Originally Posted by jpmillington View Post
    Hi, I was feeling a bit frustrated with all of this, especially as earlier on I had been trying to repair my Quad tuner (which Ive had for 35 years or so and which decided to blow up the other day) - replacing capacitors etc to no avail.
    So, I thought Id have a look at the connectors under the apron and the earth before it got dark - guess what? 10 minutes of cleaning/scraping and everything now appears to work fine. All I can say is thanks everyone.
    Now, back to the Quad....
    As the saying goes, many hands make light(s) work! Glad you sorted it. Peter.
  2. #12 Re: Lights!
    Jun 2015
    Kelsall Chester
    549
    Not to rub it in , with fiberglas cars ally caravans in fact most auto electric problems check the earth return first. Use a jumper lead from the battery earth to the iffy component, then work back. With caravans especially lighting faults are usually earth faults. Sometimes it is easier to put in a permanent earth return wire rather than fid a hidden corroded conection.
  3. #13 Re: Lights!
    28
    A little knowledge.... thanks, Dave
  1. Lights issue
    By Rfc1drew in forum Roadster
    Last Post: 03-03-2016, 08:03 PM
  2. New lights fitted.
    By Gareth in forum What did you do with your Marlin today
    Last Post: 23-05-2015, 10:34 AM
  3. Berli lights
    By PaulW in forum Berlinetta
    Last Post: 07-08-2013, 02:46 PM
  4. Side lights
    By CosworthCabrioLee in forum Cabrio / Hunter
    Last Post: 29-04-2012, 06:19 PM
  5. Brake lights
    By Ryanhooley in forum Roadster
    Last Post: 16-11-2005, 11:40 AM
