Thread: Triumph Rear hub puller
Results 1 to 10 of 14
  1. #1 Triumph Rear hub puller
    Sep 2018
    2
    Hi there currently undertaking full body off restoration of my Roadster (GT6 running gear) and looking for a local Hub Puller to borrow or buy?! Any ideas, Cheers.
    ...Based in Bath
  2. #2 Re: Triumph Rear hub puller
    North Wales
    364
    I used a 2 legged on JRR but it was bent getting it off.
    Boy was it tight I should have used the gas axe on it!! Ideally you need a 4 leg puller but I don't know if there is such a beast
    Anyway it cost me a new hub, from Rimmer Bros.
  3. #3 Re: Triumph Rear hub puller
    High Wycombe, Buckinghamshire
    1,893
    There is but, boy, are they expensive. The pullers that is.
    Quote Originally Posted by djj_engineer View Post
  4. #4 Re: Triumph Rear hub puller
    3,199
    Rimmer Bros sell them. Not cheap though.
  5. #5 Re: Triumph Rear hub puller
    Club Member David's Avatar
    High Wycombe
    1,126
    What about this... on eBay. Seems like a good design bolting to the hub rather than trying to 'hook it' so to speak.
    Hydraulic Wheel Hub Puller
  6. #6 Re: Triumph Rear hub puller
    SE London
    2,186
    Thats a good price considering it has a hydraulic ram and multi fitting options
    https://rimmerbros.com/Item--i-RX1542
    this heavy generic Triumph tool is OK but has no hydraulic advantage
    so needs an extra shredded wheat in the morning.
    The alternative would be to remove the assemble and get a local garage to press it off.
  7. #7 Re: Triumph Rear hub puller
    3,199
    Quote Originally Posted by b_caswell View Post
    Ben has it right. I have a friendly mechanic with a 20 ton press, for a box of teabags and an hours chat, hubs and bearings magically fall off, and more importantly the new bearings get refitted.
    Its a bargain compared to the cost of a puller.
  8. #8 Re: Triumph Rear hub puller
    Sep 2018
    2
    That's all really helpful - the reason I'm doing it is that I need to change the worn/torn old rotoflex donuts... any wisdom or advice greatly appreciated! )
  9. #9 Re: Triumph Rear hub puller
    Exeter
    1,229
    Quote Originally Posted by timbuck2 View Post
    Worth checking the Triumph specialists to see if they do cv joint upgraded drive shafts. The money for a puller would go towards the cost of them! :-) Peter.
    PS . Links below. Ouch!
    https://rimmerbros.com/Item--i-RG1314
    https://www.canleyclassics.com/diffe...onversion-kit/
  10. #10 Re: Triumph Rear hub puller
    1,893
    Re-mortgage time.
  1. For Triumph 6 cyl fans
    By b_caswell in forum Roadster
    Last Post: 23-02-2015, 05:09 PM
  2. Help with my Triumph Starter Again Please
    By greggpearson in forum Roadster
    Last Post: 09-11-2010, 05:21 PM
  3. Puller for Marina car halfshafts
    By jonathanbaggott in forum Roadster
    Last Post: 26-01-2010, 10:38 AM
  4. Triumph Heater triumph!
    By tymill in forum Roadster
    Last Post: 22-01-2007, 09:16 AM
