Triumph Rear hub puller
  • Triumph Rear hub puller
    Hi there currently undertaking full body off restoration of my Roadster (GT6 running gear) and looking for a local Hub Puller to borrow or buy?! Any ideas, Cheers.
    ...Based in Bath
    Re: Triumph Rear hub puller
    I used a 2 legged on JRR but it was bent getting it off.
    Boy was it tight I should have used the gas axe on it!! Ideally you need a 4 leg puller but I don't know if there is such a beast
    Anyway it cost me a new hub, from Rimmer Bros.
      There is but, boy, are they expensive. The pullers that is.
        Rimmer Bros sell them. Not cheap though.
          What about this... on eBay. Seems like a good design bolting to the hub rather than trying to 'hook it' so to speak.
          Hydraulic Wheel Hub Puller
            Thats a good price considering it has a hydraulic ram and multi fitting options
            Order your Hub Puller 4 Stud Type (Triumph) - RX1542 ⛽ Low prices and fast, worldwide delivery ✈ British car experts ♚ Call ☎ 01522 568000 or ☎ 1-855-746-2767
            this heavy generic Triumph tool is OK but has no hydraulic advantage
            so needs an extra shredded wheat in the morning.
            The alternative would be to remove the assemble and get a local garage to press it off.
              Ben has it right. I have a friendly mechanic with a 20 ton press, for a box of teabags and an hours chat, hubs and bearings magically fall off, and more importantly the new bearings get refitted.
              Its a bargain compared to the cost of a puller.
                That's all really helpful - the reason I'm doing it is that I need to change the worn/torn old rotoflex donuts... any wisdom or advice greatly appreciated! )
                  Worth checking the Triumph specialists to see if they do cv joint upgraded drive shafts. The money for a puller would go towards the cost of them! :-) Peter.
                  PS . Links below. Ouch!
                  https://rimmerbros.com/Item--i-RG1314
                  https://www.canleyclassics.com/diffe...onversion-kit/
                    Re-mortgage time.
                      Isn’t there somewhere the story of how the factory did this using off the shelf parts, maybe cheaper if those part are still available.
                        As much as I like Triumphs I have always managed to avoid the Mk2 rotoflex cars Certainly need to read up on the shimming of the hub on rebuilding.
                        there is a way of building a hybrid CV drive shaft using some Volvo parts but not familiar with whats involved.
                          I'm certainly glad JRR doesn't have Rotoflex!
                            This may be worth reading if you interested but does involve some engineering.
                            Scroll down to December 7th.
