Thread: roadster hood swb
Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11 Re: roadster hood swb
    High Wycombe, Buckinghamshire
    1,862
    Hi Phil
    What make of sailmakers tape would you recommend as there are so many.
    Quote Originally Posted by phil.coyle View Post
    Forgot to mention about sailmakers tape, widths from 12mm and upwards, stickier than a sticky thing and useful for assembling pieces together before stitching.
    For lift dot fasteners have a look at Chandlers and all Marine related fasteners, usually the best suppliers for stainless fittings, and if you want I can give you a method to perfect an oval for a rear window.
    Warning about sail makers tape, if it sticks to itself, that's it use a new piece and only cut it off the roll, believe me its amazing.
    Phil
    I used Pvc, I don't have any photos as I moved a year ago from Droitwich to Prestatyn and a lot of my (not needed at the moment) resides in a container but ONE DAY.
  2. #12 Re: roadster hood swb
    Moderator Club Member
    Derby
    1,376
    Good stuff, but can be tricky to sew through in some cases as adhesive builds up on needle. I've used various luff and spinnaker repair tapes when dinghy sailing, bought from chandlers.
    Probably Bainbridge international or 3M stuff , can't remember exactly
  3. #13 Re: roadster hood swb
    Jul 2016
    St Austell, Cornwall
    575
    All good advice and thanks.
    My shopping list is getting longer.
    Cheers, Martin.
  4. #14 Re: roadster hood swb
    361
    The sail tape I used was double-sided 12mm and I used it just to do a dummy run before final stitching.
    As Dogoncrazy says the tape is not good to sew through as thread and glue are not a good combination, so after taping the seams with the doublesided tape, clamp the seams together with bulldog clips or the smallest clamps you can find and remove the tape as you move along the seam, just don't fit it altogether at once unless you are part octopus.
    I had dark brown hair when I made mine, now I'm getting ready for my once a year job at the local department store, ho, ho,ho.
  1. Roadster hood
    Last Post: 07-11-2018, 03:09 PM
  2. Roadster Hood
    By pads1964 in forum Roadster
    Last Post: 06-04-2018, 02:37 PM
  3. New Roadster Hood
    By ggrum in forum Roadster
    Last Post: 27-07-2017, 04:46 PM
  4. New Hood for Roadster
    By darren.fisher in forum Roadster
    Last Post: 14-04-2010, 08:29 AM
  5. Roadster hood bag
    Last Post: 02-04-2007, 03:26 PM
