Wheel, wheel nuts and wheel Studs
  • Wheel, wheel nuts and wheel Studs
    Time for a question and answer
    1 What are the wheels?
    2 What are the Wheels nuts?
    3 What are the Wheel studs?
    The info you have
    1 It is a Marlin Roadster with Marina front and back axles complete
    2 The wheel nuts are 3/8" UNF Thread 1.5 " long and the plain portion is 5/8" diameter and 3/4" Long.
    3 The wheel Studs are 3/8" UNF Threads 1.375" long and the hole in the hub is 1/2" diameter.
    Any Info on the above would be welcome. The engine and gearbox are Alfa Romeo.
    Derek
    Wheel, wheel nuts and wheel Studs 2
    Hi DJ not sure why first thread was closed but my answer is:-
    1 The wheel any clues on the back?? cant match that one.
    2 The nuts look similar to ealy Dolomites that had alloy wheels later cars had 7/16th unf
    3 The studs are normal marina/Triumph Herald etc.
      Re: Wheel, wheel nuts and wheel Studs 2
      I have "opened" this thread and moved Ben's answer here from a second thread.
      I will delete the second thread as it is not now required.
        I found this on the web:
        Other cars with the same 4 x 3.75” (95.25mm) PCD (Pitch Circle Diameter).
        Austin: Marina
        Lotus: Elan, Europa, Seven
        Triumph: Herald, Spitfire, GT6, Vitesse
        MG: Metro, Montego, Maestro, MGF
        Formula Ford Racers
        Can you confirm the PCD?
          IIRC Rover 100/Rover Metro (i.e. K series engines) are 3.75"...Austin/MG Metro (i.e. A series engines) are 4" (as per Mini)...
