Thread: LED Rear Lights
Results 1 to 7 of 7
  1. #1 LED Rear Lights
    Dec 2015
    37
    Hi,
    Was wondering if anyone has tried these lights almost the same dimensions as the original units?
    B07NVH1FG9 they are on Amazon for £14 a pair
    Best Regards
    Graham
  2. #2 Re: LED Rear Lights
    Sep 2017
    Tamworth Staffs.
    189
    Graham if there is an indicator I think there has to be a resistor put into the circuit to stop them flashing like a strobe.
  3. #3 Re: LED Rear Lights
    Apr 2018
    Southland - NZ
    46
    I'm using LED's all round - you need an LED flasher unit to go with them
  4. #4 Re: LED Rear Lights
    2,929
    Don’t forget the hazard flasher too.
  5. #5 Re: LED Rear Lights
    Dec 2015
    37
    Thanks guys
  6. #6 Re: LED Rear Lights
    South Somerset
    494
    I've just brought them. When fitted I'll add some pictures and information.
  7. #7 Re: LED Rear Lights
    Apr 2019
    38
    When I rewired Wee Beastie I used a three terminal flasher unit. These have a timing chip in them and they flash no matter what. The old two terminal thermo electric units required a load to work but the three terminal electronic ones do not.
    Formally DonSayers on here.
