Thread: Spiyda Gauge Matcher v4
Results 1 to 10 of 12
  1. #1 Spiyda Gauge Matcher v4
    High Wycombe, Buckinghamshire
    1,831
    Well that's got to be the best 30mins I have spent fitting a device to make my Marina Fuel Gauge work with the escort sender.
    I used it setting up the resistance figures given to me from the Escort Club -
    75 ohms Empty
    50 ohms 1/4 full
    25 ohms 1/2 full
    17 ohms 3/4 full
    10 ohms Full
    Not cheap, £50 but works a treat and it now reads empty, 1/4, 1/2, 3/4 and full correctly.
    I would definately recommend.
    Will work on any gauge and any sender, whatever the make.
  2. #2 Re: Spiyda Gauge Matcher v4
    High Wycombe
    1,123
    That’s a result, how long as that device been hiding on someone’s shelves!
  3. #3 Re: Spiyda Gauge Matcher v4
    1,831
    They appear to sell a lot and this is the upgraded v4.
    All I know it works.
  4. #4 Re: Spiyda Gauge Matcher v4
    frequent forum contributor Club Member Blue Marlin's Avatar
    Mar 2015
    Old Kilpatrick, Scotland
    262
    I've got one fitted to Brum. It is ideal for her as the Alfa fuel gauge fitted works in reverse to the Escort sender, with 0 ohms being empty.
    I drained the tank then refilled a quarter tank at a time taking note of the resistance readings.
    0 - 75 ohms
    1/4 - 45 ohms
    1/2 - 27 ohms
    3/4 - 20 ohms
    4/4 - 10 ohms
    Pretty close to what you were told.
    Stumbling around in the dark
    Marina based SWB roadster
  5. #5 Re: Spiyda Gauge Matcher v4
    1,831
    Knew I was teaching others to suck eggs but sometimes it's the obvious that gets overlooked.
    Glad it does what it says on the box.
    If you do get one watch all the YouTube videos, makes it very easy to install.
    Quote Originally Posted by Blue Marlin View Post
    0 - 75 ohms
    1/4 - 45 ohms
    1/2 - 27 ohms
    3/4 - 20 ohms
    4/4 - 10 ohms
  6. #6 Re: Spiyda Gauge Matcher v4
    1,831
    Next on the list is to get the tachometer working again.
    I went accuspark and meant that the RVI stopped working.
    This device, from the same guys, will convert my original dial to RVC.
    I will let you know how I get on.
    Smiths RVI - RVC Tachometer conversion board + calibration cable -566-
  7. #7 Re: Spiyda Gauge Matcher v4
    Chester
    374
    Cheers for that, very interesting. I'll be looking into this very soon! Gareth.
  8. #8 Re: Spiyda Gauge Matcher v4
    High Wycombe
    1,123
    You need to stop making things work Adrian, makes some of us feel inadequate
  9. #9 Re: Spiyda Gauge Matcher v4
    Jun 2015
    Kelsall Chester
    581
    Just a reminder, I cut out the Ford sender and soldered in a Marina sender. A bit of jiggling to get the float swing right and I now have a full scale fuel gauge.
  10. #10 Re: Spiyda Gauge Matcher v4
    1,831
