Thread: Speedometer Access
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
  1. #1 Speedometer Access
    Suffolk
    361
    My speedo has stopped working so I need to find out if it’s a cable problem or the speedo itself. Either way I’m going to need to access the back of the speedo and there lies the problem. It would seem that the instruments have been mounted through the wooden dash and into the alloy dash behind therefore locking the two together so I can’t access the top screws that fit the dash to the dash mount moulding. I’m probably missing something obvious but anybody got any ideas how to get to the back of the speedo?
  2. #2 Re: Speedometer Access
    South Somerset
    504
    Sorry, can't help directly. I've got a plain ally dash covered in black leathercloth. There is a dash capping which on my car is screwed at either end, the screw heads aren't visible unless the door is open. Maybe that may reveal further fixings.
  3. #3 Re: Speedometer Access
    Club Member dcunn's Avatar
    1,329
    Like this I think (but it's a Hunter)
  4. #4 Re: Speedometer Access
    Suffolk
    361
    Ive got the dash capping off ok but its the dashboard itself I can't figure out how to remove. According to the build manual the alloy dash is attached by a series of screws, some on the underside roughly where the heater controls are located which I can see but the others are just under where the capping overlaps but in my case I either haven't got any or they are under the wooden dash. My layout is almost identical to the one above except there is a small screw each end roughly where the small speakers are. With these removed I can gently lever the ends of the wooden dash away from the alloy one but it seems pretty obvious that the wooden dash is clamped in place by the speedo and rev counter.
  5. #5 Re: Speedometer Access
    forum contributor
    May 2017
    Exmouth
    7
    Quote Originally Posted by ggrum View Post
    You will have to remove the alloy dash with the wooden one. I removed mine last year for a similar reason, and the screws holding the alloy were revealed when the capping was off. There were larger holes in the wood so that the screw heads went through it and tightened against the alloy. Any sign of the wood being filled to hide the heads?
  6. #6 Re: Speedometer Access
    Suffolk
    361
    Good thought Geoff but there is no evidence of any filled holes. As I mentioned before I can pull the wooden dash away a couple of mm from the alloy one at the ends having taken those screws out but its firmly attached in the middle region where the instruments are. It seems that the instruments are clamping both the wooden and alloy dashboards together and I don't think I can get to the back of them with the dash in place. I really can't work out how the builder assembled it in the first place unless he built the dash up first and assembled the rest of the car around it!
  7. #7 Re: Speedometer Access
    forum contributor
    May 2017
    Exmouth
    7
    I can only suggest looking behind the dash with a torch and a mirror, (and possibly a contortionist), to see if there are any hidden screws along the top edge.
    Incidentally, my problem turned out to be a failed nylon speedometer drive gear in the gearbox. Fixable, but I fitted an electronic speedo instead.
  8. #8 Re: Speedometer Access
    Suffolk
    361
    Have you tried finding a contortionist these days!!! Oh well, I'll continue to think on. Thanks for your ideas.
  9. #9 Re: Speedometer Access
    frequent forum contributor Club Member David's Avatar
    High Wycombe
    1,112
    I've found that poking my smart phone with camera on 10 second day behind the dash gets some goo pics.
  10. #10 Re: Speedometer Access
    Nov 2016
    69
    Hi Geoff
    If you want a hand give me a call. I can still manage to contort my frame into the most unlikely of places.
