Thread: Painting a cast iron exhaust manifold
Results 1 to 6 of 6
  1. #1 Painting a cast iron exhaust manifold
    frequent forum contributor Club Member 928cdu's Avatar
    Jul 2016
    Warwick
    144
    Any one have any good recommended paint & preparation methods for re-finishing a cast iron exhaust manifold.
    I needed to the the old herald manifold off as the studs were stripped, causing the exhaust to blow. Whilst I have it off, I thought it deserved a lick of paint.
    Don't want something that will last 5 minutes !
    Any suggestions welcome !
  2. #2 Re: Painting a cast iron exhaust manifold
    Club Member dcunn's Avatar
    1,459
    Mornin' Richard - I don't know about High temperature primers but in the past I've found High Temp paint
    spray cans (use several coats) to be quite effective direct onto a degreased (use cellulose thinners or meths) surface
    For longevity the finish needs to "cook off" and the instructions for this are on the cans
  3. #3 Re: Painting a cast iron exhaust manifold
    458
    In my experience the only coating that has any longevity on a cast iron manifold is rust.
  4. #4 Re: Painting a cast iron exhaust manifold
    Jul 2016
    Warwick
    144
    Thanks for your suggestions Dave and Paul, I eventually went for Paul’s option. I couldn’t stand the car being off the road another week !
    The old studs refused to come out, so they had to be drilled, holes re-tapped and new studs.. test drive later !
  5. #5 Re: Painting a cast iron exhaust manifold
    High Wycombe, Buckinghamshire
    1,901
    Hi
    My mate with his 1965 e-type jag has used this and still looked good after the drive to Le Mans Classic and back via Calaise.
    Rustoleum 1078-7778-1015-7715 High Temp Black-Aluminium(1).pdf
  6. #6 Re: Painting a cast iron exhaust manifold
    458
    Just to prove I wasn’t being flippant I got this from Wikipedia “As with other metals, like aluminium, a tightly adhering oxide coating, a passivation layer, protects the bulk iron from further oxidation.”
