Thread: De Lorien Marlin
Results 1 to 10 of 10
  1. #1 De Lorien Marlin
    High Wycombe, Buckinghamshire
    1,830
    OK, it took some 240 grit paper, pre-paint and WD40 to get the brushed look.
    Three coats of clear lacquer and that's a finish I could live with.
    Decision made, I will do all the aluminium myself.
    Finished item on right.
  2. #2 Re: De Lorien Marlin
    1,830
    Used a Scotchbrite pad and, in my opinion, is even better.
    The centre one has the reflections of the trees.
  3. #3 Re: De Lorien Marlin
    Jul 2016
    St Austell, Cornwall
    552
    Good idea Adrian but your grass needs cutting. 😀
  4. #4 Re: De Lorien Marlin
    1,830
    Cheaky bugger
    Good idea Adrian but your grass needs cutting. ������
  5. #5 Re: De Lorien Marlin
    Jun 2015
    Kelsall Chester
    581
    Maybe one of the robotic mowers so that the human can get on wiyh more fulfilling tasks. Will lacquer bond to ally without etch primer? If I don't use etch primer on the Landrover the paint will flake off.
  6. #6 Re: De Lorien Marlin
    Jul 2016
    552
    Wonder what finish a fine grit flap sanding wheel on a drill would give with light use.
  7. #7 Re: De Lorien Marlin
    1,830
    It appears to, I am going to leave the test pieces outside to see what happens.
    I'll let you know.
  8. #8 Re: De Lorien Marlin
    1,830
    Might work, I'll give it a try and let you know the outcome.
    A
  9. #9 Re: De Lorien Marlin
    Nov 2016
    72
    I thought everything fell off Land Rovers!
  10. #10 Re: De Lorien Marlin
    Jun 2015
    Kelsall Chester
    581
    Bits only fall off because they rattle. If the bolts are tight they don't. It is difficult to bolt paint on, you need big washers!
