Thread: Coil overs
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
  1. #21 Re: Coil overs
    Nov 2016
    57
    It would be of interest to know what figures/weights you used in the calculation, especially corner weight, un sprung weight and shock ride height. Also wondering what the rating would have been for the original torsion bar -Anyone know?
    Looks to be a good mod and not mega bucks either.
  2. #22 Re: Coil overs
    regular forum contributor Club Member nigel_cordrey's Avatar
    Jul 2017
    20
    Quote Originally Posted by A_Hogg View Post
    bit of guesswork involved and measurements taken from my Marlin.
    The corner weight is working on the total weight being around 740kg with 50/50 weight distribution
    https://www.marlinownersclub.com/for...ghlight=weight
    and it can't be to far off because when I lowered the car of the jack, the springs compressed the 2 1/2 inches I was after.
  3. #23 Re: Coil overs
    Nov 2016
    57
    Many thanks
  4. #24 Re: Coil overs
    Apr 2018
    Southland - NZ
    49
    Excellent!
    I had not realised just how much of an angle the damper sat at
    The 0.584 - "motion ratio" means that the spring moves for 0.584 inches for every inch the wheel moves - and you SQUARE that to get the required spring rate
    So despite the 250 lb/ft springs your Marlin is SOFTER sprung than my Device with 110 lb/inch springs and a little more weight
  5. #25 Re: Coil overs
    462
    Quote Originally Posted by duncan View Post
    Excellent!
    Hi Nigel
    I think you have the angle of the shock absorber wrong. I believe it should be 70 degrees not 40!? From the instructions on the website you have used it says "find the angle of the centerline of the spring or coil-over assembly from the horizontal"
    I think you may have input the angle between the shock and the lower arm when in the steady state and as the lower arm is at quite a steep angle downwards from chassis to wheel then this has crept in an error.
    I may be wrong but wanted to point this out just in case so that others who may be thinking of following your design can be very sure.
    Jon
  6. #26 Re: Coil overs
    Apr 2018
    Southland - NZ
    49
    Quote Originally Posted by jon_cox View Post
    Hi Nigel
    Jon
    If the measure was taken from the vertical instead of the horizontal then the 40 degrees becomes 50 degrees and from that calculator the "motion ratio" becomes 0.696 - which as it is squared means that 30% softer spring is needed to get the same effect
  7. #27 Re: Coil overs
    Nov 2016
    57
    I have measured mine and got 55 degrees from the horizontal. This then gives a spring rate [to nearest round figure] of 200 lbs
