Thread: Cabrio Rear Spring change
Results 1 to 10 of 11
  1. #1 Cabrio Rear Spring change
    frequent forum contributor Club Member bryannewell's Avatar
    309
    Hi All
    Is it possible to change the rear coil springs on a cabrio(sierra base) with rear swing arms in place?
    Obviously I would need a Spring compressor
    I have removed rear Dampers to allow some slack, Is it then just a case of compressing and removing?
    Bryan
    Stapley Bryan
  2. #2 Re: Cabrio Rear Spring change
    Jun 2012
    Sandbach
    243
    I did my rear coil springs with the rear swing arms in place with spring compressors a bit fiddly but no great problem, access was easy as I did have the rear tub off when I replaced them.
    I still have the spring compressors I used, you could borrow them although distance apart would be a problem.
    I think I paid about £10 for them off Ebay
  3. #3 Re: Cabrio Rear Spring change
    309
    Hi Dave
    Thanks for the reply and the offer but as you say distance a problem!
    I'll buy spring compressors and give it a go if I have to I think I can disconnect the Drive shafts to give some more movement
    Out of interest did you stay with Standard Spring Rates?
    Stapley Bryan
  4. #4 Re: Cabrio Rear Spring change
    Exeter
    1,176
    Hi Bryan. If you buy spring compressors make sure they are’nt too long as there isn’t much clearance above and below the springs. I tried my old ones for Sierra front struts but they were too long to fit.
    That said, when I repainted my rear suspension I removed the springs without compressing them by putting the rear chassis on axle stands, disconnecting the lower shock absorber bolts and letting the swing arms down on a trolley jack. I think it was when I replaced the rear lobro drive shafts, as you mustn’t bend those joints too far from their normal operating range. Peter.
  5. #5 Re: Cabrio Rear Spring change
    309
    Hi Peter
    Thanks for the headsup, I've ordered a pair which I think will do the job
    I tried earlier just undoing the shocker bottom bolt but there is not enough movement with Driveshafts attached so i'm hoping I can compress springs and remove with Driveshafts in place
    I'm just hoping I didn't do any mischief to the Joint on my first attempt (should have read the Haynes first!!)
    Bryan
    Stapley Bryan
  6. #6 Re: Cabrio Rear Spring change
    Jun 2012
    Sandbach
    243
    Hi Bryan
    I bought the standard rate springs brand new, I did measure mine and the seller checked that his were the same I recall being more concerned about getting the same size.
    I did not need to disconnect the dive shafts, I did turn the spring top adjusters up to their full extent.
    Think you may bash your knuckles a few times apart from that all should be OK
    Dave
  7. #7 Re: Cabrio Rear Spring change
    309
    Hi David
    I decided to remove drive shafts rather than wait for spring compressor and I could not shift the top adjusters!
    I rang my local parts dealer and as I have no info on donor whatsoever he came up with three different lengths/diameters so have measured mine and nearest is 299mm x 131mm so will go with that
    Out of interest did you renew the rubber Bump stops? Mine are turning to powder and is part of the reason I am taking things apart, But as I've been thinking about it I can't imagine them ever coming into play being as how are cars are so much lighter than a standard car
    Bryan
    Stapley Bryan
  8. #8 Re: Cabrio Rear Spring change
    Jun 2012
    Sandbach
    243
    Hi Bryan
    Just checked my bump stops they look very good, I must have renewed them although I do no actually recall sourcing them.
    My adjusters were also difficult to shift, I did use heat to loosen them
    Dave
  9. #9 Re: Cabrio Rear Spring change
    Exeter
    1,176
    Quote Originally Posted by bryannewell View Post
    Hi David
    Bryan
    There are some o/e ones for sale on Amazon albeit at a price.
    https://www.amazon.co.uk/Genuine-For.../dp/B06XY74NJB
    On my Hunter they look more like a squashed ball (with a recess that pops over the locating spigot) rather than a cylindrical shape like the Ford ones.
    I think my exhausts hit the ground long before the bump stops come into play! You can probably fit them later with the suspension just jacked up, so not a job stopper. Peter.
  10. #10 Re: Cabrio Rear Spring change
    Jun 2012
    Sandbach
    243
    My bump stops are the same as yours, same with exhaust which I found to be so whilst doing a recent navigational night rally.
