Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: New member
  1. #1 New member
    Feb 2019
    cheltenham
    21
    I would like to introduce myself, Barry Liles, and I live in Cheltenham. At the moment my all-consuming project, which had been laid up for 13 years, is a Marlin Mark 1 Triumph based Reg.No. JGC 433C.
    It consists of Herald front suspension and most everything else is from a GT6. It has a 2.5 ltre TC engine overhauled by Rimmer Bros I would guess at the time of original build. It has gearbox with overdrive, differential and drive shafts with Rotoflex, which again are GT6. As yet have not been able to find chassis number.
    I'm going through everything servicing and replacing all as necessary and hope to get it finished by next Stoneleigh.
    Look forward to meeting you all then.
    Barry
  2. #2 Re: New member
    club member Club Member jon_wilkinson's Avatar
    Mar 2016
    Macclesfield, Cheshire
    395
    Welcome to the forum.
    Have you have looked on the front nearside chassis leg where the number should be? If so, and it's not there hopefully the Club has some history based on the reg. no. Expect an answer soon :-)
  3. #3 Re: New member
    Suffolk
    489
    Welcome to the club. I'm sure our archivist will be able to help you with this one but I believe he is away for a few days. As Jon says, expects an answer in the near future.
  4. #4 Re: New member
    club member Club Member b_caswell's Avatar
    SE London
    2,225
    Its a Mk1 the kit number if there is one will be on the left side of the bulkhead punched into the ally.
    Email me as in Pit Stop and I can give you some history.
  5. #5 Re: New member
    1,649
    Hi Barry and welcome from me too
    Using Ben's diagram above your car should have 1115 01 04 81
    .........and this is what it would (should)(could)(may) look like :
  6. #6 Re: New member
    Feb 2019
    cheltenham
    21
    Hi All
    Many thanks for your help. It would seem that the serial number was punched into the ali on left hand side behind battery. All of that ali was missing from my car having been replaced with ply. The evidence of battery acid rot was still there in some of the black painted angle steel. Also the ali above the pedal box was very pitted leading to replacement, so serial number probably lost unless the archivist turns up something.
    Again many thanks to you all
    Barry
  7. #7 Re: New member
    Mar 2016
    395
    Barry, I think DC was saying that your car's number is 1115 01 04 81 from his records. He will correct me if I'm wrong.
  8. #8 Re: New member
    1,649
    Jon, you're correct. Shame that apparently there will not be proof of the kit number on the car itself
    but at least we are certain of it's provenance......you could always re-stamp it to look like the above !
    The car has also carried another registration number during it's life, and we do have some history.
    As Ben has said (and he is after all the "T" guy) send him a private email and between us he and I will share
    with you what we have in the archive, it's too detailed to put on here
  9. #9 Re: New member
    Feb 2019
    cheltenham
    21
    Hi Dave
    That will teach me to read what you had written properly. I will soon have that ply ripped out. Can anybody tell me the height of the numbers so I can source the right die set.
    I have already sent an email to Ben.
    I am very grateful for your help.
    Best wishes, Barry
  10. #10 Re: New member
    Jan 2015
    51
    Hi Barry , Welcome , I'm not a million miles away in Dursley with a MK1 being rebuilt too , at this rate Stoneleigh 2025ish finish planned . Good luck with you project . May catch up sometime
