Thread: Marlin Cabrio - hood seal
Results 1 to 6 of 6
  1. #1 Marlin Cabrio - hood seal
    Jul 2018
    12
    Does anyone have experience of fixing leaking soft tops? The hood on my Marlin Cabrio has a defective seal where it closes onto the windscreen - the current seal is made up of a double layer of rubber piping and I have been told by the resident soft top expert at the Morris Minor centre in Bristol that there should be a better type of seal available to use. He is willing to make the repair but has left it to me to find the correct seal. I have written to Terry at Marlin, but she is on holiday until 22/07 so I thought that maybe someone else can recommend the correct product to use?
  2. #2 Re: Marlin Cabrio - hood seal
    South Somerset
    506
    Dunno-but if you find out please share!
  3. #3 Re: Marlin Cabrio - hood seal
    Nov 2016
    74
    I think the original idea was closed cell foam strip of maybe 3mm x 20mm bonded to the forward edge of hood, full width. Other members have used 'D' section rubber again full width and either side of the securing pegs. They can be obtained in various sizes from Woolies or Seals Direct
  4. #4 Re: Marlin Cabrio - hood seal
    Jan 2016
    Rugby
    230
    Quote Originally Posted by A_Hogg View Post
    When mine needed replacing I used this:
    https://www.carbuildersolutions.com/...trip-per-metre
    As mentioned above this is bonded to the forward edge of the hood. I ran two pieces side by side to give a good width and its a nice snug fit. Not had any issues with water ingress.
  5. #5 Re: Marlin Cabrio - hood seal
    Jul 2018
    12
    Many thanks for the useful suggestions - I should have remembered good old Woolies from the time I restored an MGB GT back in the early eighties. I'm torn between using the flat strip or the D shaped product, but the flat strip worked well for one member so I may just go with this one. Thanks again to you all.
  6. #6 Re: Marlin Cabrio - hood seal
    frequent forum contributor Club Member kahawi's Avatar
    Jan 2018
    Bideford, Devon, UK
    67
    This is our hood, front frame:-
    Two flat strips, with an extra one on top (underneath)? You can probably work out the dimensions.
    It seals very well in Exmoor rain!
