Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Alernator charging problem.
  1. #11 Re: Alernator charging problem.
    3,399
    It certainly sounds like an alternator fault.
    Over the years I have used many small companies to repair alternators, starter motors and some large proper industrial motors, all with favourable results.
    they were all on the south coast though.
  2. #12 Re: Alernator charging problem.
    May 2016
    152
    It's definitely an alternator fault. Either one of the diode packs has gone bad. However if your lucky it might be a sticking brush in its holder not contacting the commutator.
    Is the Alternator Bosch or Magnetti Marelli ? I ask because the Bosch is a all in one unit held in on the back of the alternator and can be changed in situ , after of course first disconnecting the battery. That unit is approx £10 new off ebay iircc held in by 2 flat screws.
    Looking something like this:
    https://www.ebay.co.uk/itm/Beru-GER0...IAAOSwojhbSLTU
  3. #13 Re: Alernator charging problem.
    club member Club Member element's Avatar
    Dec 2015
    Crieff, Perthshire
    271
    It is a Magnetti marelli; it's at the repairers now..
    2002 Marina based LWB Roadster with Fiat 2.0 TC engine & box
