Thread: Running-Board strip, End-Caps?
Results 1 to 8 of 8
  1. #1 Running-Board strip, End-Caps?
    frequent forum contributor Club Member kahawi's Avatar
    Jan 2018
    Bideford, Devon, UK
    72
    Has anyone encountered these end-cap fittings for the running-board strips please?
    Lost one over the weekend and it looks to have been stuck on with double-sided tape.
    Car Builder Solutions do something that looks similar, but not exactly the same, meaning replacing all 12 on the Hunter. Advice appreciated.
    Last edited by kahawi; 05-08-2019 at 02:36 PM. Reason: increased spacing before photo
  2. #2 Re: Running-Board strip, End-Caps?
    Nov 2016
    78
    Might be something available at boat chandlers or caravan supplies.
  3. #3 Re: Running-Board strip, End-Caps?
    Jul 2016
    St Austell, Cornwall
    569
    You could make one that looks almost the same. A piece of aluminium, a file and some elbow grease should give you something.
  4. #4 Re: Running-Board strip, End-Caps?
    Nov 2016
    78
    Simples!!!!!!!!!!!!!
  5. #5 Re: Running-Board strip, End-Caps?
    Bodmin, Cornwall
    723
  6. #6 Re: Running-Board strip, End-Caps?
    Crewe Cheshire
    25
    I'm going back many years. I have similar fitted bought from Beauford Cars ( are they still in business? )
    I believe they sourced them from Italian scooter manufacture.
    Perhaps you could research that source on the internet.
    Since moving house all my build records are stored in the loft so can not supply better information.
    Good luck.
  7. #7 Re: Running-Board strip, End-Caps?
    Crewe Cheshire
    25
    Been up in loft and found the following:
    I bought 12 in 1994 from Beauford Cars (based in Upholland, Lancs)
    Cost £10.58 (see photo)
    They where self adhesive, I have had one come off, used the double sided tape for number plates to re-attach.
    Hope this all helps. Dave
  8. #8 Re: Running-Board strip, End-Caps?
    Aug 2019
    12
    HI
    Try EBay for Vespa end caps.
    Ray
