Thread: Project roadster on eBay.
Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 47 of 47
  1. #41 Re: Project roadster on eBay.
    Jul 2016
    St Austell, Cornwall
    566
    Typo? instead of 1978cc could be 1798?
  2. #42 Re: Project roadster on eBay.
    Jun 2015
    Kelsall Chester
    602
    No engine pictures. Not properly registered could be a big problem. It does look like a barn find maybe a relative's old car. I wonder if the seller is reading this?
  3. #43 Re: Project roadster on eBay.
    Jul 2019
    55
    Seller has confirmed it is an '1800 cc' engine.
  4. #44 Re: Project roadster on eBay.
    3,106
    Quote Originally Posted by marlin1984 View Post
    I can’t see the point of boring out a ‘B’ series to 1950, the max that I understand is possible, unless you want to retain MG heritage, but it’s power output is always going to be limited bu by the three port exhaust manifold. An engine/transmission swap seems to be much more sensible for a kit car, if you want more power.
    There is a more interesting alternative, a Marina owner bolted a Zetec head onto a ‘B’ series block, I will let you search for that, but it seems to work.
  5. #45 Re: Project roadster on eBay.
    Jul 2016
    566
    Going back to the project roadster at the Lizard. If the buyer is or becomes a MOC member and local to me and needs some body panels, I have a spare used rear tub, some running boards and rear arches.
  6. #46 Re: Project roadster on eBay.
    Club Member dcunn's Avatar
    1,350
    Just back on the site after computer repair, checked the archive and found these - proof that it was Marlin on
    the road, these pics seem to show two different locations. Edit - maybe I should not say it was on the road as no obvious tax disc
    …. but it looks like a complete car !
  7. #47 Re: Project roadster on eBay.
    Jul 2019
    55
    Quote Originally Posted by stevejgreen View Post
    Just maybe someone wants to do serious trials and the narrow ACTC spec. means Zetec head transplants are interesting - but out. [A Ford gearbox change seems OK though.] I agree that the siamesed ports are ****! (apparently a B-series design foible brought about by lack of space).
    I like Rover V8s - but around 100bhp is probably enough in a 750kg car.
    That Zetec-headed B-series looks good by the way.
    https://www.bing.com/images/search?v...vt=0&eim=1,2,6
