Thread: 1800 B series 7 bladed yellow plastic fan blade for fitment water pump & 1-2 spacer
Results 1 to 10 of 13
  1. #1 1800 B series 7 bladed yellow plastic fan blade for fitment water pump & 1-2 spacer
    May 2016
    90
    Hi I currently have the 3 bladed early MGB fan fitted to I think is the shallow water pump pulley that originally took a 7 bladed yellow plastic fan possibly with a viscous coupling.
    Currently the fan is too far from the radiator on my Mk2 Roadster.
    I have researched that on some MGB's there was a 1" aluminium spacer that would move/site the fan nearer to the radiator.
    Does anyone have a 7 blade plastic fan going spare and either 1 or 2 of those 1" spacers and the resulting required 4 longer UNF water pump bolts needed to fit that combination please ?
    The closer I can move the fan blade towards the radiator the better, however I am aware that the limiting factor will be getting it to just before the steering rack.
    Thanks for reading this request
  2. #2 Re: 1800 B series 7 bladed yellow plastic fan blade for fitment water pump & 1-2 spac
    Jan 2016
    Rugby
    269
    Alternatively, fit a cowl to the back of the radiator shaped to funnel the air onto the existing fan? If the fan side is a close diameter to the fan it should suck the air through the radiator more efficiently? Or, consider ditching the engine mounted fan and fit an electric one direct to the radiator, there are many plus points to doing that.
    2000 Marlin Cabrio; 2.0 L Burton Pinto in Ford Nightfire Red with Magnolia leather interior.
  3. #3 Re: 1800 B series 7 bladed yellow plastic fan blade for fitment water pump & 1-2 spac
    Club Member David's Avatar
    High Wycombe
    1,126
    Several spacers on eBay at the moment...
    https://www.ebay.co.uk/itm/ORIGINAL-...8AAOSwAaxcVLrl
  4. #4 Re: 1800 B series 7 bladed yellow plastic fan blade for fitment water pump & 1-2 spac
    May 2016
    90
    Btw , I have ditched the fan and have an electric fan fitted however on long trips of 2 hours or more the engine doesn't cool efficiently enough, even with the 1800 landcrab radiator and then starts to use oil because of it running hot. It is for that reason I would like to use both. The temperature gauge and sensor are brand new and this rise in heat build up does not show on the guage. On short trips and short blasts the engine uses no oil at all and there are no leaks .
    The cooling system has been flushed now about 20 times in total, so it's not because of that .
  5. #5 Re: 1800 B series 7 bladed yellow plastic fan blade for fitment water pump & 1-2 spac
    North Wales
    364
    My MGB hated stopping. It built up heat very quickly. The people at Moss said to put the engine fan back on as it created an airflow over the engine. ( I had an electric fan fitted) So I replaced the engine fan and kept the electric fan in case!
  6. #6 Re: 1800 B series 7 bladed yellow plastic fan blade for fitment water pump & 1-2 spac
    High Wycombe, Buckinghamshire
    1,893
    Hi
    My two peneth.
    I have a kenlow and also a 7 blade fan from an MGB.
    The kenlow cools the radiator and the fan pushes the heat from the engine out via the shark fins.
    Works brilliantly, no overheating even when sitting in traffic at Le Mans Classic.
    I have to say not my idea, it was suggested by my Classic Car mechanic.
    Quote Originally Posted by djj_engineer View Post
  7. #7 Re: 1800 B series 7 bladed yellow plastic fan blade for fitment water pump & 1-2 spac
    May 2016
    90
    Hi Adrian
    This is the line of thought that I also have , i.e to use both.
    The original builder of my Roadster that I met at this years Stoneleigh recalls that it had the yellow 7 bladed fan and thinks it ran fine with just that . However in view of the fact that he built approx 20 different kit cars since, remembering what traits each build had unless they were recorded, it is possible that his info might night not be entirely accurate.
    The reason I posted was because some people have moved on from the B series and might have the required parts gathering dust in their garage. Of course I am able to source new parts off ebay or Moss.
    Interestingly there have been a lot of failures using the Moss supplied 7 blade fans see the following:
    http://mgaguru.com/mgtech/faulty/ft080.htm
  8. #8 Re: 1800 B series 7 bladed yellow plastic fan blade for fitment water pump & 1-2 spac
    3,199
    Beware plastic MGB fans, they have a tendency to deflect towards the steering rack fixings ultimately catastrophically.
    they might be fine at tickover, but at 5000 RPM deflect towards the radiator with the inevitable result of coming into contact with something that was not originally planned to be there!
  9. #9 Re: 1800 B series 7 bladed yellow plastic fan blade for fitment water pump & 1-2 spac
    North Wales
    364
    I didn't use the plastic fan I had the originals steel 4 blade fan
  10. #10 Re: 1800 B series 7 bladed yellow plastic fan blade for fitment water pump & 1-2 spac
    1,893
    I didn't use the spacer to get it nearer the radiator, it was just there to take the heat out from under the bonnet.
