Thread: Tachometer Morris marina 1,8
Results 1 to 10 of 10
  1. #1 Tachometer Morris marina 1,8
    frequent forum contributor Club Member kolmershlagjp's Avatar
    Dec 2015
    avignon {sud de la France]
    117
    Hello
    can we install Morris Marina Bj.71-80 Tacho 190km / h Tachometer on a roadster base marina 1.3
    merci
  2. #2 Re: Tachometer Morris marina 1,8
    High Wycombe, Buckinghamshire
    1,911
    Yep, here are mine, if you go electronic ignition then there is a company who can supply a converter which I have fitted to my tacho. All works a treat.
    Quote Originally Posted by kolmershlagjp View Post
    Hello
    merci
  3. #3 Re: Tachometer Morris marina 1,8
    Dec 2015
    117
    can you tell me or connect the white wire and the green / white wire
    merci
  4. #4 Re: Tachometer Morris marina 1,8
    1,911
    The white one goes to the ignition switch and the white and green goes to the coil.
    merci
  5. #5 Re: Tachometer Morris marina 1,8
    3,207
    Many wiring diagrams can be found on Keepandshare here or there
    BL cars and the Marina generally follow Lucas colour codes here or there
    A common joke is that you should never let the smoke out of the wires. If smoke escapes, the electric controls will cease to work, a can of Lucas smoke is available to inject back into the wiring!
    here or there and here or there
  6. #6 Re: Tachometer Morris marina 1,8
    Dec 2015
    117
    The white goes to the ignition switch, you mean 12v power supply?
  7. #7 Re: Tachometer Morris marina 1,8
    3,207
    The wiring diagrams and Lucas colour codes, say a (+ 12v) supply from the ignition switch,
    [Listerjp2 will doubtless correct me if I am wrong.]
  8. #8 Re: Tachometer Morris marina 1,8
    Dec 2015
    117
    white and green go to the coil. on the + or -?
  9. #9 Re: Tachometer Morris marina 1,8
    1,911
    No correction required, go with what Steve said.
    Good luck and enjoy your car.
  10. #10 Re: Tachometer Morris marina 1,8
    3,207
    I just thought I would do a quick search on FastMarina forum.
    i thought I had read something on there about fitting a tacho about a year ago.
    Its always worth keeping up to date with them. I’m not sure why more Roadster owners are not regular contributors or readers there.
    here or there
