Thread: Berli/Cortina Ignition Switch
Results 1 to 3 of 3
  1. #1 Berli/Cortina Ignition Switch
    frequent forum contributor Club Member B_Williams's Avatar
    Buxton
    47
    I've been having a spot of bother with the ignition barrel on the car; essentially it's getting worn out.
    The switch end seems OK, but the key is getting harder and harder to insert correctly, to both turn and to push in release the steering lock. Actually the barrel is pushing in too soon and preventing the key from being inserted far enough for all the tumblers to disengage.
    From what I can make out, the whole part is common to Mk3 Cortina, and Mk1 Capri, and little else. That being housing, switch and key/barrel assembly as one unit.
    Does anyone know what else they were used on, or a source for a replacement.
    I don't have a parts book to look up the genuine Ford number; Is anyone able to assist please?
    Also, if I do find one, or just the key/barrel, does anyone know how to release the old barrel without wrecking the housing?
    I suspect that the actual barrel/key assembly might be common to other models, but no idea which ones.
  2. #2 Re: Berli/Cortina Ignition Switch
    431
    This has a diagram for Ford Taunus/Cortina (1970-1975) but does not list the parts for some reason.
    http://www.fordopedia.org/parts-cata...tina-mk3/H1.10
    Not a great deal of help.
  3. #3 Re: Berli/Cortina Ignition Switch
    Buxton
    47
    The answer would seem to be that there's at least two types; unfortunately it looks like mine is the earlier and harder to find one, rather than the one from ebay which I was assured was correct.
    Mine's the one on the left with the roll pin to hold it all together, and is held in place by a curved spring, rather than a brass detent pin.
    Note also the smaller boss at the inner end.
    If anyone has one in their "ready for the tip/disposal" box, I could find it a home, even if it's broken, as I could work on refurbishing it whilst still keeping the car on the road.
    Quite happy to buy one of anybody knows a source.
    I think it's Mk3 Cortina/Capri and Taunus spec.
