Thread: Marlin trails car
Results 1 to 10 of 16
  1. #1 Marlin trails car
    forum contributor
    Feb 2019
    1
    Hi there I'm looking to fit a 10cwt ital rear axle into my trails car and wondered if I should fit van rear springs to improve ground clearance or will it make it too stiff what has everyone else done please? Thanks Alex
  2. #2 Re: Marlin trails car
    3,150
    That’s really a question for the Trials boys.
    Bearing in mind that a Roadster is a lot lighter than a Morris Marina.
    Do you know what your existing springs are, presumably but not certainly from the original donor, but was it a 1300, 1800, or an estate?
    This document might help https://kvisit.com/S1Mb2AQ
  3. #3 Re: Marlin trails car
    frequent forum contributor Club Member AndrewKB's Avatar
    Cheltenham, UK
    98
    Springs are huge area of debate in the Marlin trials world, with no clear 'industry standard' (yet). Personally, if you have a set of van springs, I would fit them and worry about alternatives after you've done a few events. Lots of people have played-around with alternatives but there have been a lot of spring failures. I have van springs on my Marlin, and they are stiff, but I now think that the shock absorbers may have had-their-day and are contributing to the stiffness. Replacing them is a priority when there's a decent lull between events (too busy at the moment).
  4. #4 Re: Marlin trails car
    Cheltenham, UK
    98
    PS - See https://wheelspin.info/marlin-roadster/ and then please Contact Me so I can keep my Register of Trials Marlins up to date.
  5. #5 Re: Marlin trails car
    Jul 2019
    61
    10cwt Marina or Ital van axles are now pretty rare. I counted myself very lucky to find an [unidentified] one on fleabay a couple of months ago. Key identifier was the cast iron [therefore slightly rusty] diff housing - standard ones are alloy. Good luck.
    Steve Green may have a couple back in England but as he's now in Spain access is extremely difficult.
  6. #6 Re: Marlin trails car
    3,150
    Quote Originally Posted by marlin1984 View Post
    True, they are in the loft of my garage in the UK, but I rarely return and dragging them out and arranging postage/delivery when I have tenants there it would be quite an inconvenience, so for the sake of discussion, they do not exist.
    Should the consequences of Brexit or life mean I have to move back to the UK, they may become available, but don’t hold your breath.
  7. #7 Re: Marlin trails car
    Jul 2019
    61
    Quote Originally Posted by AndrewKB View Post
    Maybe - but "had-their-day" shocks normally get weaker/more feeble with wear rather than stiffer … ?
  8. #8 Re: Marlin trails car
    Exeter
    1,202
    Some years ago now I had some Spax adjustables on my Mk 2 Cortina. They failed as they became progressively harder and although the adjuster screws would turn they wouldn't soften up the ride. Peter.
  9. #9 Re: Marlin trails car
    Jul 2019
    61
    ??? I did say "normally" because that has always been my experience - maybe Spax are constructed differently to nearly every other make ?
    Have had Spax adjusting screws go solid though [thanks to exposure to water].
  10. #10 Re: Marlin trails car
    Apr 2019
    47
    Standard Marina, van and Ital diff housing were not ally they were cast iron.
    Formally DonSayers on here.
